Results 1 to 2 of 2
    Apr 2016
    Austin, Texas
    Default I am in need of info on how to replace LED light on my fender 2015 Spyder F3-S SE6
    Hey Guys/Gals,
    I am trying to figure out how to replace the buld on my F3-S. I have never touch the fender area before. So i guess my question are as following
    1) to access the bulb do I have to remove the tire?
    2) How much of the fender do I have to remove to get access to the bulb
    Thank you in advance
    Fee
    Jun 2010
    Las Vegas
    Does your fender have an amber and red reflector on it or does it have just the tip light and a channel? If it is the first type you have to remove the wheel or you can remove the fender. On the second type you remove the tip light by pushing the tip light back, then lift up.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
