Results 1 to 3 of 3
    Apr 2012
    Lonsdale MN 550046
    Default 2012 RT thermostat
    Thinking my thermostat is gone. The weather is the primary control of the heat guage instead of the engine heat.
    How do I change it?
    Oct 2014
    Fort Mill, SC
    If your temperature gauge is reading about 25% when the outside temperature is about 50F and then reads a little over 50% when it is around 80F, you're normal.
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    Member: American Legion
    Nov 2015
    Chardon, OH
    Right. The thermostat is external to the motor. You've got a lot of coolant system plumbing running between the motor and the thermostat for the bypass flow path. On those cool days there's enough ambient cooling that your engine temperature hangs low in the band. Completely normal for the V-Twin. Thermostat failures are extremely rare. Don't worry unless you overheat.
    Doug
    ”Freedom is not a loophole”
