Results 1 to 7 of 7
    Active Member wingit3611's Avatar
    Dec 2016
    Louisville, KY 40214
    Default Turn Signel Lever, left
    Has anyone had to repair the lever? Something came loose in there and it doesn't attivate the left turn. Hoping I can repair this. 2012 RT SE5
    Can Am 2013 RTL SE5
    Oct 2015
    Lynden, WA
    Please keep us posted on your attempts and successes at opening the left signal module.
    I have tried and found the unit to be sealed and the internals to not be accessible.
    Others have been able to access the PTT switch and make modifications so I trust
    the unit can be opened just not successfully by me.
    Good Luck, David C.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Nov 2018
    Waynesboro, PA
    You might try just excising it a little. I have had to do that with mine. I take the mirror off and unplug it and then plug it back in making sure the connections are clean and then work the handlebar switch back and forth a hundred times so it cleans itself and makes good contact. I would try that first. I have had that issue and it cleared up by doing this. I have a 2012 RTL SE5
    2012 RTL , Brown
    Active Member SpyderJerry's Avatar
    Aug 2017
    Deerfield, Wi
    Quote Originally Posted by wingit3611 View Post
    I just replaced mine on my 2013 rt se5. It is a sealed unit, no way to replace or repair dir switch. I found one on ebay for $44.00. A little work to replace though. My old one still works, but I had to always push in while turn on left directional.
    2014 RT SE6
    Active Member jcaburto's Avatar
    Jan 2017
    Whittier, Ca
    Mine is beginning to fail too. I'm glad to hear that the switch can be purchased separately and I won't have to change the whole left housing.
    Whys is it only the left one failing? Do we pull too hard on it?
    Julio Aburto
    Black Currant 2013 Can-Am Spyder RT Limited
    2013 RTL , Black Currant
    Dec 2016
    SpyderJerry: I'd be interested in your old one if you want to part with it. ?
    Can Am 2013 RTL SE5
    Aug 2017
    Deerfield, Wi
    I would probably like to keep it for a spare. Keep tabs on Ebay, I'm sure more will show up.
    2014 RT SE6
