Results 1 to 12 of 12
    Very Active Member Rogue Hawk's Avatar
    Apr 2015
    Chicago
    Default Anyone researching a turbo Ryker?
    I know Can Am has a turbo they are using in another application for the 900. We have some real master mechanics on this forum. Are any looking into this?
    2019 Rally , Black
    Active Member poli's Avatar
    Feb 2019
    East Texas
    Just my opinion but the rear wheel is easy to spin now. Double the hp and you couldn't use most of that extra power anyway.
    Spyder F3-S Special Series my traveling ride
    Ryker Rally modified for dual sport duty
    Honda Grom heavily modified for dual sport duty
    Ducati Scrambler Icon Dark my other traveling ride
    Active Member spyderider1's Avatar
    Jan 2018
    Wisconsin
    It's not the same engine. The turbo 900 is a much more robust version, i.e. pistons, heads, and crank. Same displacement but a different engine to accommodate the boost, heat, etc. The snowmobile application goes from 90 hp to 150 hp with the noted changes.
    LORD GRANT ME THE SENILITY TO FORGET THE PEOPLE I NEVER LIKED,
    THE GOOD FORTUNE TO RUN INTO THE ONES I DO LIKE,
    AND THE EYE SIGHT TO TELL THE DIFFERENCE.
    2016 Spyder RTS
    Very Active Member Tslepebull's Avatar
    Dec 2018
    East Texas
    Quote Originally Posted by Rogue Hawk View Post
    Y'all done lost your minds! It already has plenty of power for me!
    2019 Ryler Rally , Shock Yellow
    Apr 2019
    California
    Quote Originally Posted by poli View Post
    You sure could at higher speeds and improve the top end where the Ryker is lacking.
    Plus, people have done wider tires in stickier compounds already.
    The Ryker absolutely could use a turbo.
    Feb 2019
    East Texas
    Maybe BRP will come out with a turbo model for those that need it. I'm just saying that since I am usually going 15 to 25 mph I have all the power I need.
    Apr 2015
    Chicago
    Quote Originally Posted by Tslepebull View Post
    There is never enough power
    2019 Rally , Black
    We went through the same thing when the 08/RS came out. A couple nice people on here blew up their engines trying to turboize them.
    Brings back thoughts from Star Trek: "We need more power Scotty."
    Very Active Member Purple Guy's Avatar
    May 2013
    Edmonton Alberta, Canada
    Considering the Ryker was introduced to accommodate a lower price point, having a model with a turbo + the added infrastructure needed to make it safe IMO would be non starter...
    2014 RT-Ltd , Cognac
    Sep 2013
    Johnson, Vermont
    Nothing to research. BRP already has a turbo version of the 900 ACE. They just need to add it to the Ryker as another option. To me this seems like an easy decision but knowing BRP it will never happen?
    Active Member vstrommer's Avatar
    Oct 2015
    miNNESota
    I think we are fortunate that BRP turned down the Nanny on the Ryker muchness asking for a Turbo......
    2019 900 Rally , Black
    Apr 2019
    California
    Quote Originally Posted by Rob Rodriguez View Post
    If it sells well you would think more models would be introduced especially a turbo version considering they already have the motor.
    If they don't someone else will capitalize on it as it seems the three wheel thing is catching on.
