Page 2 of 2 FirstFirst 12
Results 26 to 36 of 36
  1. #26
    Feb 2019
    England
    Hi Rob yes you can do that ( remove seat / fit top box swap over when you want. Regards Nico 75
  2. #27
    Jan 2019
    North Carolina
    Quote Originally Posted by Winnex3 View Post
    yes very easy if you have the maxmount
    +1 recommendation on the Givi Top Case if you have the MaxMount. I was able to affix the universal bracket to it like this:
    2019 Can-Am Ryker 900 RE
    2019 900 Rally Edition , Black w/Yellow Panels
  3. #28
    Feb 2019
    Richardson,TX
    Looks like my installation. Holds box very securely.
  4. #29
    Jan 2015
    southern WI
    Quote Originally Posted by WilliamTRyker View Post
    Did you get the backrest pad too? My wife is looking for more back support than the OEM top case offers
    2021 RT Limited
    2016 RTS , Pearl White
  5. #30
    Jan 2019
    North Carolina
    Quote Originally Posted by Mazo EMS2 View Post
    No, when I ordered it, both the backrest pad and brake lights were out of stock.
  6. #31
    Apr 2019
    OH
    Quote Originally Posted by rocinante54 View Post
    Greetings, all. I'm pondering the acquisition of a Ryker (the 600 version is currently the only one we can ge here in Cali). I've been over on the website looking at the accessories and I saw that CanAm is offering a top box. I understand you have to get the mounting bracket for the top box.
    I have two Givi Monolock top boxes which I currently use on my Silverwing and Burgman 400. I'm wondering if there is a way to install a Givi Monolock mounting plate on the CanAm rear bracket, so I could use my Givi boxes on the Ryker.
    Very informative group, here. Thanks in advance for all reponses.
    Yes. With the Max Mount installed, I bought a Shad SH33 and mounted it to the Max. Had to position and drill holes in the mount. Looks awesome and matches the Shad side mount hard case.
  7. #32
    Very Active Member campermac's Avatar
    May 2015
    Etters PA
    before you get the Givi lights take a look at www.admorelighting.com
    2022 RT Limited , Silver w/ Black and Purple accents
  8. #33
    Jul 2020
    USA
    Did you have to do any retro-fitting or use any other hardware than what was provided? How stable is it? Thanks!
  9. #34
    Jun 2020
    New Jersey, USA
    Hardware included is fine. I used three brackets across the front and one in the back center.
  10. #35
    Very Active Member Tslepebull's Avatar
    Dec 2018
    East Texas
    I was able to salvage and reuse the top case from my wrecked BMW shown in my avatar.
    I bolted it directly to this mounting plate for the Max Mount that I found on a Canadian site. https://spyderzone.ca/en/product/lin...yker-top-case/. After the exchange rate the price for the mounting plate is lower than I have seen elsewhere and the BMW case matches the Rally very well. The whole arrangement is very sturdy.
    2019 Ryler Rally , Shock Yellow
  11. #36
    Jan 2019
    North Carolina
    Quote Originally Posted by rush1967 View Post
    Same.
