Results 1 to 16 of 16
    Active Member Micnice10's Avatar
    Jan 2019
    Rochester, MA
    Default Glove box lock vid
    https://youtu.be/1E66EGmpSt8
    Nice YouTube vid on glove box and how it locks!
    Very Active Member Markubis's Avatar
    Jan 2018
    NH
    It's nice to see that Can Am had the forethought to make designs for both the gas cover and the trunk lock-able by using one mechanism. It could be that they just didn't have time to finish the locking mechanism...OR....they opted to leave it like that and make it an add-on.
    Either way is fine by me. I'm just happy that they thought about it while in the design phase.
    Jan 2019
    North Carolina
    I wish they would just announce an official add on, because I would buy it.
    2019 Can-Am Ryker 900 RE
    2019 900 Rally Edition , Black w/Yellow Panels
    Bossier LoUiSiAna
    Still needs hazard lights along with fork & parking brake lock, Not as after thoughts. Have seen the P-brake from vendors, still looks easily defeated, as light & small as the Ryker is wouldn't be much effort for some crook to roll it off.
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Active Member mikeyuberalles's Avatar
    Feb 2019
    Clearwater, FL
    I look forward to seeing what Quasimotard rigs up to make use of that lock.
    Jan 2019
    Toowoomba Qld Australia
    Came across it last night. Good find by Quasi. Hopefully MkII will have all these little niceties included and/or come out as addons.
    2014 ST-S , Cognac
    Jul 2016
    australia
    In Australia we get the hazard lights and park lock standard
    Mar 2019
    Ruidoso Downs, New Mexico
    Not waiting for Quasimotarded to come up with something, I've sourced a solenoid. I removed it from my FJR when I got it, was used to keep the (even smaller) glovelet box locked with key on. It 'pulls' so I have to come up with a connector to fasten the bolt to the gizzmo on the Ryker latch. Shouldn't be too difficult.
    2020 F3L; gone but not forgotten are all the good miles!
    Feb 2019
    Clearwater, FL
    Quote Originally Posted by McRuss View Post
    Keep us posted.
    Mar 2019
    Quote Originally Posted by mikeyuberalles View Post
    Keep us posted.
    Design in progress.....but I REALLY NEED my Rally to make it work! Date is now May 3, 25 days; but who is counting?
    So far I've decided that the solenoid will push the 'locking lever' closed with power off and retract to open it with power on. Mating the solenoid to the lever will be the biggest issue but I'm pretty good at fabricating solutions from left over parts (heaven knows I have enough of those!) And I'll need to source a hot lead but not sure how the RFI 'key' is going to affect that. Anyone found a 'keyed' source for power up front somewhere?
    Active Member Zoot's Avatar
    Mar 2019
    AZ
    What about the feed to the instrument panel - is that switched? Might have to add a relay.
    Dec 2018
    NY
    Try the accessory port on the left side under the colored panel.
    Current: 2022 CAN AM F3S SS. Manta Green, Route 129 windscreen.
    Previous:CAN AM Ryker Rally. Intense black, side case , comfort drivers seat, comfort passenger seat with back r test, wind screen, LED auxiliary lighting.
    2022 F3S, special series , Manta Green
    Mar 2019
    Quote Originally Posted by Jsmith8695 View Post
    That's what I'm looking for ! I think....if it is switched. I'm just not sure how accessories 'hook into' the CANbus wiring system. I'm thinking I'll get a universal fuse block, pull 12V from the battery and then run any/all farkles from that. Good ones give an option of switched or unswitched/live.
    Active Member vstrommer's Avatar
    Oct 2015
    miNNESota
    2019 900 Rally , Black
    Mar 2019
    Yes, EB is one of the best. There are others as well
    https://www.twistedthrottle.com/dena...or-motorcycles
    I've also used Blue Sea but I don't think they offer switching options like EB and Denali.
    The only issue I see with EB is that they don't mention CANbus compatibility. Oops, I just found it: A protective diode can be ordered inline on the ignition switched lead, preventing reverse EMF flow back to the bike. This is highly recommended for CANBus bikes.
    Mar 2019
    Keep us posted.
    Unfortunately life got in the way of my project. That and I lost (in my office on the floor.....) the little spring from the solenoid piston! Got the Rally now though and when I get a chance to remove the frunk, I'll get back to the project!
