Results 1 to 5 of 5
    Dec 2015
    Louisville Kentucky
    Default Side cargo insert replacement
    My right side rear cargo hinge broke off. I ordered the hinge upgrade but my hinge was broke off the insert. I ordered a new insert. Has anyone replace this?
    Quote Originally Posted by Benmannino View Post
    I doubt if many have needed to this …… but if yours is Broken to the point of - No other Option ….. The insert just bolts into the cover …. Good luck ….. Mike
    Dec 2015
    Louisville Kentucky
    Thanks, it looks like I have to remove part of the back trunk maybe the seat and possibly the side panel, it has four screws onto of the piece not just the face.
    Very Active Member Purple Guy's Avatar
    May 2013
    Edmonton Alberta, Canada
    Sadly it doesn't just "bolt" into the cover.
    Didn't state what Spyder you have so this is for an RT...
    See attached photo as to what your Spyder will look like when you finally get the insert removed!
    A little tip, look at your new insert, on the back of the insert there are 2 small holes that have small screws that are quite hidden when on the Spyder.
    If the damaged insert is on the muffler side you will need to drop the muffler as well...
    Highly recommend installing the hinge upgrade kit while replacing the insert!
    Good Luck!
    2014 RT-Ltd , Cognac
    Dec 2015
    Louisville Kentucky
    I need to take all this off just to replace the insert? Wow
