Results 1 to 25 of 25
    Jun 2018
    Pa.
    Default Having dealer use a "car" tire as a replacement on a Spyder
    I called a local Spyder repair show concerning replacement of the stock Spyder tires with a car tire. I read the posts of our community saying the last longer and rider better. He would not entertain it and said it was a liability issue. How did other get the replacement done? I am in no way shape or form qualified to do it myself.
    Thanks,
    Jim
    Sep 2014
    USA
    Call around and see who does motorcycle tire changes some auto shops can do them too if they are setup
    I agree. If your dealer can't or won't see the light, you just have to try harder. Being able to remove the wheels and take them somewhere will help you greatly. The rear wheel is usually the sticking point with this approach. But if you can manage this hurdle, you should be able to get it done.
    As far as I know, in the 10 years that people have been putting 'Car' tires on their Spyder, there have been zero liability issues. I'd say that is a much better track record than some of the things that dealerships do on a regular basis. It has always amazed me that putting a better product on your vehicle constitutes a liability issue. Sometimes I wonder if it isn't more of a revenue issue.
    Jun 2017
    Rapid City, SD
    The guy I get my tires from said no problem, “when you need new ones on the Spyder we will take care of it”. He said he had ones that would work. I only have 6000 miles on mine so it will wait a while.
    HE>I
    2017 RT , Asphalt Grey
    Active Member Chasinsparks's Avatar
    Jul 2016
    Woodbine, Maryland
    I just did it yesterday on the front, bought the tires online took the wheels off the Spyder went to Costco and had them mounted and balanced.
    To be continued....
    Active Member Raprider's Avatar
    Oct 2017
    Central NJ
    Where in PA are you? I'm pretty sure that SmithMarineUSA.com in Doylestown told me they would handle this when needed.
    Check around...
    Raprider (Rich)
    2016 Can-Am Spyder ST-S SE5 Steel Black Metallic (Blackbird)
    BRP Audio, Heated Grips, Fog Lights, Passenger Backrest, Givi Saddlebags/Top Case
    BajaRon Swaybar, TricLed Wide-Vu Mirrors, Lamonster Ram mount and X-grip, Sena 20S Evo Dual
    TricLed Sequential Front SpyderFenderz, Dual Color Run/Brake/Turn LEDs, Brake Flasher
    Kumho Ecsta AST installed on rear 4/2021
    1996 Yamaha Virago 750 (Vera) - still riding
    1987 Honda Shadow 500 (Shady) - sold
    1982 Honda Rebel 250 (Little Reb) - sold
    Apr 2017
    North Central Florida
    Quote Originally Posted by JimH View Post
    Either he is a moron or is lying to you.
    This is no different than putting higher load range tires on your car or truck.
    There is NO "liability issue".
    The stock Spyder tires ARE car tires; just very low load range ones.
    Default Hit and miss
    Some dealers are installing car tires others will not. I know when we installed customer supplied parts we had a disclosure they signed to that effect and we were not liable or did we warranty the job. But check with ryding buddies, spyders to the rescue and even other bike shops to see if they will help out even if just to get the wheels off and back on again. Wheels alone can be done at most tire shops....
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Feb 2019
    Portland, Oregon
    Has anyone tried RUN FLAT car tires with their stiffer sidewalls? If so, your thoughts?
    "They" do it on Wings and other bikes all the time. Just keep checking around if that is what you want. The persistent always win. There are many, many threads offering helpful advice as to which tires are good. And...we have never heard of a major tire failure caused by a car tire on a Spyder.
    Nov 2008
    las vegas, nv
    4th dealer I called is willing to do it with signed waiver.
    Tech said he is number 3 master spyder tech in the nation.
    He doesn’t recommend car tires on spyder due to damage it can do if I have a blow out but he will install whatever I bring in. He also said that some have went back to kenda because they didn’t like the ride but those may had too high of an air pressure.
    6 states down 42 states to go
    Quote Originally Posted by aka1004 View Post
    The " BS " meter just went off the scale …. …….. " BLOW OUT " …. tubeless tires don't /can't blow out ….not even the crappy Kenda's ………… His knowledge isn't just LOW … He is dangerously stupid..... His claim to be #3rd master spyder tech in the nation ….. Not based on what He has said so far …… Maybe 3rd. from the bottom ………… jmho … ( and probably others as well ) ….. I wouldn't let Him touch my lawnmower ……. Mike
    May 2017
    Mesa, Arid-Zone-A
    I don't know how run flats would react on a Spyder. They came on my BMW Z4 and I couldn't get rid of them fast enough. Because of their stiffness, they track with every little pavement seam. The car handled much better after they were gone. I also found out not every tire shop was equipt or willing to install run flats. They are so stiff that some shops were worried about damaging wheels during installation..... Jim
    Semper Fi
    Member crw's Avatar
    Jun 2017
    Griswold Ct
    wheel are designated with a code car tires are designated J bead spydre are J beads
    the shops want to sell there tires
    2013 RT , LAVA BRONZE
    Quote Originally Posted by canamjhb View Post
    ….The RUN flat tire thing came up years ago ….. I did quite a bit of research and decided EVEN they came in a size that would fit I wouldn't buy them ….. Mike
    Apr 2017
    Ask him how he thinks that would be any different than with the stock Kenda tires.
    Hint: It isn't.
    Feb 2019
    Portland, Oregon
    Thanks fellas. I was just curious about run flats and you filled me n very well. I won't even consider them for a car. That's what I like about this forum.
    That's fine. No problem signing the waiver. Probably first thing to get thrown out if it ever went to court anyway. (But don't tell them that!)
    How did he determine this? I didn't know BRP ranked their tech's nationally. Does he have an official plaque on the wall or something? I'd say a bit of a wiggle on the BS meter there.
    He doesn’t recommend car tires on spyder due to damage it can do if I have a blow out...
    Whoa Nelly! We got a whopper going there! I suppose Kenda's don't do any damage when they 'Blow Out'?! And which do you think more likely go? One that balloons out at speed, wears in the middle with only 2 ply steel belts in the tread? Or the one that does not balloon out, wears evenly across the entire tread and has 4 ply steel belts?
    The real story here is that blow-outs are pretty much unheard of on the Spyder. And if you do have a blow-out. You've got much bigger problems than what tire you are running.
    I would agree with him here. Some have gone back to the Kenda for the softer compound. But some have aired their car tire to the specs. on the tire itself. Since the tire is designed to carry a heavier load than the Spyder. You need to compensate with a lower tire pressure. Usually 24 psi is good to go on a Spyder mounted car tire (Rear).
    The other factor here is that just because a tire fits your Spyder, does not mean it is an ideal replacement for the Kenda. You need to do your homework and not just slap any old car tire on.
    The message here is that there are still dealerships that think they can flim-flam the unsuspecting customer. They don't realize that customers have good alternate sources for information these days. And it's getting harder than ever to pass off wooden nickles. Hang in there! You're on the right track. And done right, you'll find it well worth the effort. It's always hardest when you do it the first time.
    Very Active Member Fat Baxter's Avatar
    Sep 2014
    Central Alabama
    I talked to my local dealership's manager last year about their "no substitute for Kenda" policy. He claims their umbrella corporation's lawyers came down with the policy. He knows all about J-codes, etc. He also claimed that another Spyder dealer in the region was successfully sued for "putting car tires on a motorcycle" after a rider was killed in an accident. He also said that me signing a waiver won't hold up in court.
    I need a new rear tire, but the third-party, Spyder savvy guy who mounted my last one (General Altimax RT43) moved away, and none of the other dealers in my region will mount anything other than Kendas. Not even with a waiver. So it appears I'm fooked.
    Mar 2019
    France
    Think also run flats use a different wheel (inside profile)
    2009 GS SE5 , Red (Ferrari Red :) )
    Mar 2019
    France
    Watch this and contact the guy I did https://www.youtube.com/watch?v=L0VfkJRKHOM
    Quote Originally Posted by Fat Baxter View Post
    I'd like to get more information on this. I can't find anything in a Google search. But then I looked specifically for lawsuit involving a Spyder. And this case, if it is true, may be in regards to an actual motorcycle. Which is a completely different animal with a lot more legal exposure for a number of reasons.
    Apr 2017
    Total BS.
    Call him on this.
    I bet he can't give you a jurisdiction and case number for this obvious lie.
    Very Active Member JerryB's Avatar
    May 2014
    Beaverton, Oregon
    Hi Easy Rider,
    Re: I bet he can't give you a jurisdiction and case number for this obvious lie.
    It never ceases to amaze me how so many auto/etc dealers out there think that the internet forums do not exist.
    The days of them feeding us their BS is long gone.
    Jerry Baumchen
    'I'll never forget what's her name.'
    'Things are more like they are now than they ever have been before.' Dwight Eisenhower
    2008 GS SE-5
    Quote Originally Posted by JerryB View Post
    Hi Easy Rider,
    Jerry Baumchen
    Thank you & ...…………….. Mike
