Trunk Rack.
Ordered a show chrome black trunk rack. Any thing special about the install I need to know?
Measure twice, drill once....😁
Just take your time so you get it right but not a tough install....
2012 RS sm5
We need a few details, such as, what bike are you installing it on.
I have an RT and installed the show chrome black trunk rack.
Long before the trunk rack, I installed the custom dynamics high mount brake light.
The brake light interfered with the show chrome rack. I couldn't fit the rack on properly
Show chrome makes leg extensions. I needed to buy and install the extensions.
If I had not previously installed the high mount brake light, the rack would have installed straight out of the box without any modifications.
I hope this helps, but without further information on your install, I'm not sure that my experience may be useful.
IBA #47122
2020 RT Limited Asphalt Grey
New Spyder owner, and I'm not knocking the trunk rack. But have an honest question about it.
The warning label on my 2018 Limited says do not exceed 20 lbs load for the trunk. How do you fill the trunk up, then strap another bag on top of it without exceeding the 20 lb limit? I'm just wondering what your packing strategies for the trunk AND the trunk rack at the same time would be.
2018 Spyder RT Limited
AF they never did have to carry bed rolls or sleeping bags, half tents. I sure did like going to their mess hall tho
You would be surprised how handy the rack is when your at a rally or bike show / swap meet, if you find something and the box is just a little to big to fit in the back trunk put it on the rack. 20lb is a lot for example, I just got a set of floorboards that came in a 15x10x6 inch box it only weighted 12lbs. Would have had to put that on the rack if I had taken the Spyder to a bike show.
Buy a second strut to hold the trunk open. The rack will make it a little too heavy for the stock strut to hold it open.
2021 RT Limited
Just installed one on my 2014 RT Ltd, not a problem. Only thing I would recommend it to start off with a small drill and work up to the proper size. Looks great.
The racks work very well and you can move from RT to RT that are the same color in minutes.
I looked at one somewhere, it was quite expensive, as I remember about 525 freakin' dollars. WTF, over?
Safety chrome
I have a rack in "safety chrome " from the said company. I put the rain suits and cover ( plus a few sundries ) and it dosen't over load the trunk. Heavier things go in the two saddle bags ( which lowers the CG ). Cost was in the $200 range.
Lew L
Reason: cost
Tags for this Thread
