Results 1 to 6 of 6
    Very Active Member Rogue Hawk's Avatar
    Apr 2015
    Chicago
    Default Brake adjustment and a larger foot pad
    The owners manual alludes to being able to adjust the height of the break lever. But the details are sketchy. Also, the brake pad itself is very small. Is there a larger replacement?
    2019 Rally , Black
    Nov 2012
    North Las Vegas, NV
    When you flip up the foot peg you can pull out the brake pedal and turn it.http://www.lamonstergarage.com/can-a...adjustability/
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Mar 2019
    VA
    Lift the foot peg (as if you were going to adjust it), then pull outward on the actual brake lever. While pulled out you will be able to rotate it into one of several positions, then push back in and lock the peg back in place.
    Can't help on the pad.
    Quote Originally Posted by Rogue Hawk View Post
    Ryker 900 ACE - 2-up spring, max mount, passenger seat, short seat rail, Shad bag
    I put "oversize" brake peddles on both my current Spyders. I think they came from Spyderpops (a sponser here). The pads included a spacer block to "raise" the height of the peddle so it would not interfere with the foot rests.
    A picture is shown in the following photo album...
    https://www.spyderlovers.com/forums/...p?albumid=1990
    Feb 2019
    England
    Hi all ref small brake pedal , on previous bikes including Spyder I drill two small holes in pedal and make larger surface area
    Out of alloy mark through from under pedal , drill the two holes and use countersink bolts so that they protrude and are flush so boot won't catch. Regards nico75
    Apr 2015
    Chicago
    OK, thanks guys
    2019 Rally , Black
