Results 1 to 13 of 13
    Active Member SteveandBelinda's Avatar
    Jun 2016
    Canton, MI
    Default Quick Release Oil Drain Valve
    Anyone install a Fumoto type oil drain valve on their RT?
    2014 Can Am Spyder RT Limited - Pearl White
    2010 Can Am Spyder RT - Full Moon
    Mar 2017
    Salisbury,NC
    I don't have one, but look at this thread
    https://www.spyderlovers.com/forums/...ghlight=fumoto
    Active Member Dmetcalf's Avatar
    Jun 2017
    Texas
    I’m a big advocate for the Fumoto oil drain valves and have been using them for decades..! I wasn’t sure there was enough room to fit a valve in these machines..?! They are a well made product and make dumpling your oil effortlessly..!
    2016 RT-Ltd
    Bajaron swaybar
    Spyderpops trunk light
    Elka stage 2 front shocks
    Extra longbrake pedal
    brake modulator
    Centramatic wheel balancers on the front and rear.
    Rivco dual flag holder
    Tricled mirror turn signal indicators
    with American and Texas flags
    Lamonster Magic Mirrors
    missing belt guard
    Lambskin seat cover from Smokey mountain sheepskin.com
    Tricled 360 degree led Headlights
    Lamonster led fog lights
    Baker air wings
    2019 Silverado Duramax dually
    2019 Cyclone 4007 toyhauler
    Spyderpops bumpskid w led light
    Rivco brand footrest
    spydermanexhaust.com exhaust
    had my exhaust installed @ Spyder in the hills.
    Jul 2014
    Mint Hill, NC
    Clearance may be the killer issue. One parking lot speed bump and you could be in serious trouble.
    I put paper towel between the belly pan and the engine on the crankcase plug side and have never had any problem with waste oil collecting in the top side of the belly pan.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Mar 2013
    Does Fumoto have one that has the double O-ring setup like the BRP plug? There has to be an internal motor reason why they use that, so not using that could be very $ way to find out.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Quote Originally Posted by SteveandBelinda View Post
    The ground clearance is going to be an issue ………….. Also the FUMOTO Doesn't have any magnets to catch metal Debris !!!!! while the oil is circulating ……. I think the magnet is worth having ……….jmho …… Mike
    Default Not on a bike....
    They are great and have used them on the cars but not on a bike. Even though I have the front end up 2" higher I still have tell-tale marks on the bumpskid and bottom panels. Mostly from how and where I ryde. There are always the odd road hazard you may have to strattle that could snag anything lower than the pans. Now some ryders that do more touring and freeway on flatlands would be comfortable barring the occational road aligator but I like the bottom of the spyder flush like a snowboard. JMO they do make oil change neater and easier. I have the dimple plugs and those suckers leap out of your fingers with the earth magnets... especially the oil tank one.
    ​2012 RS sm5
    Jun 2016
    Canton, MI
    that's the only problem, ground clearance. Was just wondering.
    Jun 2017
    Texas
    I agree that having an internal magnet is worth having..!
    2016 RT-Ltd
    Bajaron swaybar
    brake modulator
    missing belt guard
    Baker air wings
    Jul 2014
    Mint Hill, NC
    Mrs. Lincoln had only one problem too!
    Cognac 2014 RT-S
    Sep 2013
    Houston
    Fumoto does not make one for the 1330 engine with its double o-ring plug. (that drains the engine sump and the oil tank at the same time)
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Northern Kalifornia
    Yes, there's more to a 1330's oil plug(s) than just simply being an oil plug.
    Mar 2013
    My point exactly!
