fog light switch
does anyone know if 2014 rts came with fog lights.mine has switch it lights up checked bulbs good fuse good could switch just not be connected.
Mine came with fog lights that work.
my 2014 RTS had fogs that worked too
Flatlander, Navy Veteran, Widower
Loved my 2014 RTS SE6 Pearl white
but have a new love now,
my 2017 RTS SE6 Champagne metallic (Champ)
Mine also came with fog lights. I have the same year.
I replaced fog lights in 2017.
I also replaced the headlights in 2017, because the headlight on the right side was not working.
Deanna
Gremlin Bell
SpyderPops Missing Guard Belt
Ultimate F3 Floorboards
Sway Bar with Links
Rolo Laser Alignment
Half Cover
Show chrome Trunk Shock
The Headlight on the right side of my 2016 RT LTD. also went out, and I just had both replaced. I figured if the right one failed, the left one was soon ready to faill, as the head lights remain on all of the time. My Fog Light Switch was also just replaced, the 2nd time, under Waurentee. The Switch was stuck on, and the Fog Lights would not turn on. Those Head Light Bulbs are not cheap!
Deanna
It's been awhile since I did it, but if I remember correctly the fog light wires have to be unplugged whenever the frunk is removed. I'm guessing someone took the frunk off for whatever reason and forgot to plug the light wires back together when they put the frunk back on.
I had the fog lights replaced at a dealership. Deanna
Gremlin Bell
Sway Bar with Links
Half Cover
