Results 1 to 9 of 9
    May 2018
    Jacksonville, Florida
    Default Locking a Shoei Neo Tec2 Helmet
    I have 2 orf the Shoei Neo Tec2 helmets with the new metal slide locking system. I am hoping someone on here either has or can come up with a solution for locking the helmets as they do not have a D ring for locking. I have called Shoei and they were no help other than say buy a plastic cable and lock to the bike. I would like to make something but I do not have the stuff needed. I would like to make a receiver for the metal slide that has a key lock and a way to lock to the bike. I may just stick with the cable and padlock.
    Thank you,
    Ray B.
    These are the states I have driven my Spyder Rt Limited too.
    Mudflap -- Walmart
    Tricled Headlights and Fog lights -- valueaccessories.comRimsavers -- RimBladesUSA.com
    Showchrome Tiregard (TPMS) -- motorcycleid.com
    Front and side grilles -- CanAmSpyderAccessories
    Passenger arm rest -- Diamond R Accessories
    Rear axle caps -- Lamonster
    Magic Mirrors -- Lamonster
    Yellow and red running and blinker lights on fender --Show Chrome
    TRUNK-MOUNTED, DOUBLE FLAG HOLDER -- Rivco
    Rear Brake light for trunk -- Custom Dynamics
    Bumpskid w/led lights -- Spyderpops
    Seat cushion -- Airhawk
    Cup holders -- Drink2Go
    Ultragard-4-457BK-Black-Cover-Spyder -- Big Bike Parts
    Nov 2016
    Upstate NY
    Do you have a picture of the mechanism? I cant find one.
    If you are talking about the slide latch on the chin straps instead of the 2 D rings, then the LidLock 'T' bar that you put thru the D rings then lock to the bike will also work with those slide latches. You just slide the 'T' bar thru the latch instead of the strap, then lock the end of the 'T' into the LidLock as you would normally.
    LidLocks are good that way, work with the 2 D rings OR the Slide Latch.
    May 2018
    Thank you,
    Ray B.
    Mudflap -- Walmart
    Feb 2019
    Portland, Oregon
    I have modular helmets and IMO the most secure way to lock them is with a plastic sheathed cable the goes through the eyeports and the passenger grab bar.
    Hardware stores carry the cable and the clamping devices that are simply set with a hammer. Buy enough length to be able to set each helmet on the two seats. Just make a loop at each end of the cable add a padlock and viola, you have a helmet lock.
    Feb 2016
    Count me in on the Lidlox.. Very easy to use and work with all helmets. I have ones with the slide lock and ones with D-rings.
    2020 RT Limited , Marsala Red
    Aug 2013
    Northern California
    Lidlox do work. We have Shoie Neo-Tec2 helmets and just open the ratchet mechanism and slide the T bar in and lock them on the handle bars.
    Mar 2016
    Palm Harbor, FL
    Quote Originally Posted by Daddyray View Post
    Lidlox Tbar goes through the clasp.
    https://lidlox.com/products/1012-b
    Oct 2013
    Wood Village OR
    I like to use a cable lock as when it gets hot and we stop to walk around or eat I can run the cable through my sleeve and leave my jacket with the bike and it's safe.
    2014 RTL , Black Currant
