Results 1 to 4 of 4
    Jun 2015
    Hampton Roads, VA
    Default OK - Another brake code! C0040!
    2016 RTS. This one detects a blown bulb; switch failure. Started last weekend, just popped and came up every few miles. Bulbs are OK, so assume it is the switch assembly. Ordered one ($15 or so), its a simple Cherry switch with the harness attached. Then remembered the bike is under warranty, but we all know how long (weeks!!) that can take. I gently pressed the pedal many times until the lights came on, and I think once they didn't but I'm not positive. Searching for this code I found zippy. Just curious if anyone else had it and it was the switch? Hard to replace?
    Thanks!
    Steve
    Sep 2012
    Stetson, Maine
    With BRPs Can Bus those switches could be Hall Effect switches. They look like cherry switches, but they are not. Bruce
    New to Sue and I
    Gone but not forgotten
    RTS 2011 SM5, 95,000 miles
    Mar 2015
    forrest above Reno, Nv
    Some of our 's are very sensitive to brake fluid level.
    Lew L
    2014 RTS , Circuit Yellow
    Jun 2010
    Las Vegas
    Is it clean around the switch? Crud can keep it from working properly.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
