How do I adjust clutch?
The dealer said I would just need 17 mm and Allen wrenches. But once I insert alen wrench am I still holding the nut
Need more info....
from what I can see you have an older rs/gs/rss but is it the semi-automatic or the manual. Then why are you looking to adjust the clutch, what is it doing..?? If it is slipping it can be for a variety of reasons...Let us know so we can help....
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
Ozzie Ozzie Ozzie
What is it doing that makes you think it needs an "adjustment" ?
Hydraulic clutches generally do not need to be "adjusted".
But worn master or slave pistons can cause the clutch to drag........and adjusting is not the way to fix that.
