Results 1 to 4 of 4
    Nov 2018
    St Pete Beach
    Default Pulling Codes on a 2018 Spyder RT Limited (w/ new cluster)
    I have a 2018 RT Limited with the new cluster, and just had a Check Engine Light come on with about 205 miles on the bike. Does anyone have the sequence to pull the codes on the new cluster?
    I tried the shut off , let sit, and restart approach. I then tried the approach with the mode button (tried both holding it, and pressing multiple times as could not tell from posts), but did not get to engine hours or codes (did change eco mode...). I know they went to new switch placement, the park brake being the main one, just not sure if they changed the button sequence for BRP Connect Codes..........
    Any help appreciated. Thanks
    Jul 2011
    Mitchell, Ontario, Canada
    There is a code retrieval menu item on the new dash. No need for the secret button push combo. I am going from memory here since my Spyder is still having it's winter sleep. Choose the gear icon (setting). Then it's call fault or code or something like that.
    2018 F3 LIMITED
    Jul 2011
    Default From the 2019 owners manual
    It is now listed in the 2019 owners manual.
    2018 F3 LIMITED
    Nov 2018
    St Pete Beach
    Thanks, I looked through my 18 manual and did not see it.......but do recall seeing the option when I first got the bike. Appreciate the assist.
