Results 1 to 10 of 10
    Mar 2019
    FL
    Default Typical used mileage
    What would you consider typical used mileage? For example the local dealer has a used 2015 F3 with 30k miles; a 2012 RT and 2011 RT both with 9500 miles.
    Feb 2017
    There is no pat answer in my opinion. I would have to examine each carefully and also their maintenance records (presuming they exist) before making a decision. The two RTs have the 998cc twin which you may or may not prefer. Don't know much about the F3 so someone else will have to chime in.
    We have a pair of RTs - a 2015 RT-S with the 1330cc triple and a 2012 RT Limited with the 998cc twin, and we like them both. We bought the 2015 with 436 miles on the odometer and the 2012 with over 28,000 miles. The 2012 was VERY well cared for and maintained while the 2015 was virtually showroom new. Both have performed flawlessly for us. Don't know if any of this helps or not, but an educated decision is usually a pretty good decision. So, good luck!
    May 2017
    Mesa, Arid-Zone-A
    My best guess is somewhere between 5-10K per year for a spyder that is actually being used. Of course, there are garage queens and other exceptions (Ann)..... I routinely ride 10K each year and have been doing that on 2 and 3 wheels for over most of the last 25+ years..... Jim
    Semper Fi
    Idaho
    Quote Originally Posted by kmonroe99 View Post
    Probably anywhere from 500 to 100,000 miles! As Arion says, there is no pat answer. But you should consider the mileage per year on average rather than total mileage. A Spyder ridden 2000 miles per year is likely to give you fewer problems than one ridden 200 miles per year. Any machine that is not used will deteriorate more than if it is run. Parts like hoses and seals can dry out if not kept wet with oil or fuel or coolant. We expect Spyders to go for 100,000 miles or more so one would have to have an awful lot of miles on it before mileage becomes a significant negative factor. In fact high mileage can be a positive. It'll push the price down but the bike will still give you many miles of smiles.
    2014 Copper RTS
    and on that first post.
    As mentioned above....mileage will vary. Both my current Spyders have 30K and 32K miles.
    The 30K one is a 2011....and has only been ridden on weekends by Linda. The 2014 has been ridden more and by me mostly.
    There are some "garage queens" out there. So 1000 miles for a few years old is common. There are also some high milers out there....some of us like to ride.
    Dealers can run the VIN and get the history of any The information will also include service information.
    Sometimes 's can be matched with an owner who posts on here. That also tells the tale.
    Locals also on SL may also know the machine. Just ask on here.
    Very Active Member 4 MARIE's Avatar
    Apr 2014
    Beloit Kansas
    miles on the odometer can be anything..but because of the aging spyder pilot demographic, it is
    not unusual to find super low mileage examples out there. Even newer ones. Because senior's
    situations change , and usually not in a "ryde more" way. Physical, mental, etc.
    There are some almost unused bargains out there.
    Flatlander, Navy Veteran, Widower
    Loved my 2014 RTS SE6 Pearl white
    but have a new love now,
    my 2017 RTS SE6 Champagne metallic (Champ)
    Jun 2010
    Las Vegas
    If that 15 has extended warranty I’d go for it! I sold my 14RT with 123,000 miles on it but it had 18 months of extended warranty remaining.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Feb 2012
    Spring City,Utah
    I bought my 2012 RT in 2015 with 8500 miles on it. The low mileage was due to the original owner being diagnosed with dementia and unable to ride any longer. I have put 44,000 miles on it since then.That amounts to about 9700 miles per year which I would think would be about average for a Spyder that is being ridden on a regular basis in areas with a prohibitive winter.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Nov 2017
    San Francisco Bay area
    I bought my 15 RTL used in May of 2018 with a little over 15k on it. Based on typical riding the prior owner thought that was pretty low mileage.
    2015 Pearl White RTL
    Baja Ron Sway Bar
    Russell Day Long Seat
    Strobe Brake Light
    Mirror Mount Turn Signal Indicator
    2015 RTL , Yes Pearl White
    May 2013
    Apex, N.C.
    Quote Originally Posted by canamjhb View Post
    I agree with all of the above, and have also averaged between 8-10k per year on either 2 or 3 wheels. I have been riding for almost 13 years. For the past 3 years, I have owned a 2 & 3 wheeler, so the 10k miles is being split between the 2 vehicles.
