Results 1 to 15 of 15
    Linden, CA
    Default TIME to give your BUTT a rest
    Riding time is near, those long rides are going to be way more fun if
    your BUTT DON'T HURT after only a short time riding, here is the cure...
    All you need to do is install my custom made MEDICAL GRADE seat GEL with MEMORY FOAM
    This will make your seat into one you can ride all day and enjoy the ride not thinking about
    "Damn my butt hurts" on your ride.
    conformax.jpgSeat :Gel .jpgGEL embedded in seat.jpg
    THIS IS AN EASY DO IT YOURSELF PROJECT Entire kit is ONLY $79.95
    isn't your comfort worth a little of your time and only $79.95?
    Call me TODAY
    Ride safe and COMFORTABLE
    Dave
    Feb 2012
    Spring City,Utah
    +1 on Dave's gel pad. I put one on my SpyderRT and turned the factory seat from a 2 hour seat into an all day, day after day seat. I am adverse to spending several hundred dollars to fix something the factory should have already addressed. For 3 hrs time and about $100.00( I had to buy a power stapler machine). I wasn't sure how to do part of the installation so I called Dave and graciously spent time walking me thru. Although I am not affiliated with Dave I will gladly support the sale of this product, its a great inexpensive way to get a good seat.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Mar 2018
    Manitoba
    Wow missed this thread yesterday. Sent Dave a message tonite . Got two of questions answered here. Third one is can I reuse my old cover from the corbin seat.
    Linden, CA
    yes you can
    Durham,Maine
    Dave's the man, put one on last year helped a lot!!!!
    2012 RTL , Pearl
    Nov 2018
    Virginia
    I don't want to be negative but in my experience, a gel pad left in the sun while parked will get burning hot. There goes your comfort. The only preventive measure I have found is covering it with a white towel when parked.
    They are comfortable though.
    2018 Can Am Spyder F3L, 1995 BMW R1100R, 1988 Suzuki GS250, 2019 Ryker 600 (Wife's)
    Very Active Member Big F's Avatar
    Aug 2012
    Bellevue, NE
    Call me TODAY
    Dave
    Dave: does your seat cover the seat for my back saddle mate also???
    BIG F
    Nov 2018
    St Pete Beach
    Dave, Assume the Gel pad will fit a comfort seat as well? Thanks
    2018 RT , Asphalt Grey
    Feb 2012
    Spring City,Utah
    Quote Originally Posted by Bob204bc View Post
    The gel pad goes UNDER the seat cover and becomes part of the seat. I have had mine on now for over 2 years and it has never become so hot it was not comfortable. Maybe if it was sitting on top of the of the seat it would be different.
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
    Jun 2017
    Crossville TN
    can you use them in conjunction with a beadrider? Thanks guys
    Dave
    2013 RT Limited
    Lamonster FBB with larger gripper pegs
    Value Accessories dah mount
    Custom Dynamics High Mount brake light
    BRP passenger arm rests
    Linden, CA
    Default Not hot any more
    Hi Bob
    Here is the straight info, Many years ago about 1989 or so when GEL was introduced to the public,
    it was much thicker and very dense and it did hold heat and cold for an extended time however now
    30 years later this is not the case with the Gel I use. I have my GEL made special for me by the
    same company that manufactures MEDICAL GEL, see my other website www.valleymedicalrepair.com
    My GEL is the same as used in Hospital beds, wheel chairs, physical therapy tables and equip. Dental chairs
    and much more it is NOT like all the others you may have seen, The company that makes the GEL also came up
    with MEMORY foam now seen all over in beds, pillows and such. I had them make a sandwich of GEL and memory
    for me to get rid of any chance of heat in the seat, When installing the GEL pad always put the GEL side down
    and the memory foam side UP, the memory foam is very porous millions of tiny air bubbles the memory foam does
    not retain heat or cold...Problem solved.
    Ride safe
    Dave
    Linden, CA
    Quote Originally Posted by Big F View Post
    BIG F
    It can be installed both in front and back.
    Feb 2019
    Panama City, Florida
    Is there a video that shows the process of installing these gel pads so I could see what I'd be getting myself into?
    Linden, CA
    Quote Originally Posted by AFBlue View Post
    Go to my website and on the front home page click on how to install gel
    Linden, CA
    Quote Originally Posted by Fire34 View Post
    Dave
    I guess you can but I don't see the point.
