Results 1 to 22 of 22
    Jan 2019
    Kansas
    Default Why can’t I fully fill up the gas tank?
    Hello, new owner of a 2014 RT SE6. I filled up three times, and every time I failed to totally fill the tank, at least as judged through the electronic bar I ndicator. The best I could do was reaching the second to the last bar at the top, even if filling very slowly. Does anyone have an explanation for that? Thanks!
    Oct 2014
    Fort Mill, SC
    The canister purge valve is stuck or the canister is clogged. Search this site for "Canisterectomy."
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    Member: American Legion
    Jan 2019
    Kansas
    Quote Originally Posted by Grandpot View Post
    Thank you for the suggestion. I thought that was a problem in earlier models than my 2014. And, the gas flows normally into the tank for the first few gallons, would that happen if I had the problem you mentioned? Thanks.
    Before doing any "ectomies," give the following a try.
    I also have a 2014 RT SE6. The most I have ever put in was about 5.8 gallons. I usually run the tank until the refill light goes on. For me that is about 200-210 miles.
    I fill until I see the fuel come up to the "ring." I stop...let it settle and one more time to the ring. Most of the time, this puts the fuel gauge needle up to the topmost indication. I am always afraid of overfilling. This works for me because I don't go for endurance runs on the tank. Two hundred and I want off to stretch...etc.
    May 2017
    Mesa, Arid-Zone-A
    Fill, Slowely top-off, Ride 200 miles, repeat. 2014 RTL. The fuel gage seems very accurate. It routinely begins to move off full at about 30-35 miles.
    Semper Fi
    Default They are right...
    If you stop with the self canceling nozzel you have to keep moving it higher to get more in. If you are lucky like us you will have to pull back the large rubber ring to be able to see what you are doing....
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Oct 2014
    Fort Mill, SC
    Quote Originally Posted by gianfri View Post
    As the others mentioned, be attentive as you fill the tank. If you are still having trouble, check the purge valve and canister. They provide vending as the tank is filled and will act more restrictive as the tank fills up.
    1998 Honda Valkyrie
    US Navy Veteran
    There is no purge valve on the 1330 ACE engine fuel system that I can find in any of the parts diagrams.
    Mar 2015
    forrest above Reno, Nv
    I can fill my 2014 to overflowing if I want. Yes the elephant trunk in CAL. must be pulled back to top up.
    2014 RTS , Circuit Yellow
    ............….. and the gas fill suggestions also stated ….. I have no idea where " poster #2 " got His info but it's NOT accurate . As JayBros stated above , I can't find any purge valve either ………. plus the fuel line routing in the 1330 engine applications ( for RT ) won't allow gas to get to the cannister ….. jmho …. Mike
    Nov 2015
    Chardon, OH
    Default Reset!
    Of course it has a purge valve, although it is closed when the motor is off so it is not responsible for this problem. It's just the gas tank filler neck design. If you want to really pack the tank full, as mentioned, just take your time.
    BRP has OFFICIALLY called the thing a bleed valve since day 1, I think. We all just call it a purge valve. American jargon. Part number 709000443.
    http://www.2wheelpros.com/oem-parts/...0443-part.html
    Doug
    ”Freedom is not a loophole”
    Oct 2014
    Fort Mill, SC
    Default I stand corrected
    Sorry for that bad canister and purge valve info. My head was wrapped around a 998.
    1998 Honda Valkyrie
    US Navy Veteran
    May 2017
    Mesa, Arid-Zone-A
    One other point..... There is really not much of a fill tank neck. You can look directly into the fuel tank and see how full it is. I remember seeing on this forum about someone forgetting to put the fuel cap on and getting a wet left leg after a short ride. Not good..... Jim
    Semper Fi
    Faribault, MN
    Have you tried filling up with a gas can instead of from a Gas pump? Just wondering if you get a different (better) reading on the digital gauge..
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Doug, thanks much for the purge valve correction. I didn't know it is really called a bleed valve. We all agree going slow in filling is the trick.
    Nov 2012
    North Las Vegas, NV
    Quote Originally Posted by Lew L View Post
    I call it the California Condom.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Jan 2019
    Kansas
    Thank you all for the helpful replies. I had no idea this issue was so well known! Which begs a question: why is the Spyder so much more complicated than other bikes when filling the tank up?
    Am guessing the best answer here is "because they can."
    May 2017
    Mesa, Arid-Zone-A
    Because there is literally no fill neck on the fuel tank. The fuel nozzle actually goes into the fuel tank when fully inserted. To get the tank full, I pull the nozzle out until it is barely in the hole and then SLOWELY add fuel until it starts to come out the slots in the tank nozzle fitting. And then I round up to the next 5 cent point.
    Semper Fi
    Jan 2019
    Kansas
    Quote Originally Posted by canamjhb View Post
    Any risk of overfilling when you do that?
    Apr 2017
    North Central Florida
    Probably not......because the fuel comes spitting out the vent holes/slots rather abruptly (and violently if you are running it too fast).
    I've had that happen often enough that I now only give it one "top off" squirt with the nozzle pulled out a bit.
    IF.....you get it filled to the intended point, which is designed to leave some air in the top of the tank, and the fuel gauge doesn't indicate "FULL", then you have a gauge problem, which is fairly common.
    Of course, because there really is no NECK ( like on most veh's ) if you are pumping at a rapid rate ( and some pumps are ALL on or All OFF no in-between ) … there is almost no room for any extra..... As stated above you just need to be watching what you are doing, which is what we're supposed to do …. Mike
