Results 1 to 9 of 9
Thread: Fault Codes
    Mar 2019
    Alberta, Canada
    Default Fault Codes
    I have a 2017 Spyder RT Ltd. Presently showing 3 codes I can't define...could someone help me please. They are: C0031, C0063, C0034, Brake Failure.
    Thanks you
    Default Welcome, welcome 👍
    From the codes given you have problems with the speed sensors on the front wheels C0023, C0034 and the YAW rate sensor. If you get the spydercodes app you will see the codes and suggestions. Check those sensors for GAP clearance and toothed disc. Have you done any work on the wheels, brakes or lighting around that area that may have bumped those sensors..?
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Mar 2019
    Alberta, Canada
    I had done an oil change, had the bike jacked up, don't believe I hit anything but will check. Thank you for your help.
    Jul 2011
    Mitchell, Ontario, Canada
    Take it for short drive. I will make a guess that the codes will clear themselves.
    Mar 2019
    Alberta, Canada
    I will do as you have suggested. Cheers!
    Mar 2019
    Alberta, Canada
    I tried to download the free Spyder Codes on App Store, Play Store and Amazon...the provider told me its no longer available...does anyone wish to share their Spyder
    Codes? I do have what Lamonster shared just not the Spydercodes from Apps.
    Cheers
    Jul 2011
    So I am guessing the short drive did not work? All 3 of those codes relate to sensors connected directly to the VCM. Sometimes call it the ABS module, but it does more than ABS. Maybe you bumped the harness connector for it. During the oil change. Inspect it.
    Mar 2019
    Alberta, Canada
    Everything has worked out. Your advise to take it for short ride cleared all fault codes. Thank you so much!
    Cheers
    Bossier LoUiSiAna
    good to hear glad they cleared & you know for next time. Also however when multiple codes appear it's also good to check, clean the battery terminals & connections
    Info on SpyderCodes
    https://www.spyderlovers.com/forums/...69-SpyderCodes
