Results 1 to 25 of 43
    Mar 2019
    Oklahoma City
    Default RT Vent Kit Installation Help
    Sorry if this is a request already provided but, I couldn't find anything specific regarding installation instructions for an RT Vent Kit. I ordered the kit and it was delivered without instructions. Thanks in advance for any help
    Sep 2014
    USA
    Your will need the templets too. Someone will email the info. I know someone has them here.
    Dec 2015
    Oakley Utah
    Quote Originally Posted by erua View Post
    PM me with your email address and I'll send you the PDFs
    2014 RTL Platinum
    Active Member kdp1308's Avatar
    Jul 2018
    Wichita, KS
    I assume you are talking about a 2013? If so I could take pictures of one installed.
    Active Member TheCajun1957's Avatar
    Kilgore Tx.
    Sorry, I lost the files when my laptop died. When you get the files, read through them. TAKE YOUR TIME, think things thru, make sure before you cut. Its nerve racking to think about cutting the Tupperware. the other side goes a little easier.
    2018 White F3 Limited
    Jun 2019
    Farmingville
    Can someone please post Docs install instructions?
    2012 RT-S SM5 , Pure Magnesium Metallic
    Feb 2020
    N. Wilkesboro, NC
    What vents are we referring to? What year(s)?
    May 2018
    Chateauguay, Qc, Canada
    I have some files that I have been sending to a few of the folks on here. Send me a PM and I'll send them to you.
    The vent kit is for the V twin motor RT's 2010-2013. It stops your feet from frying.
    Eckhard
    Spyder RT Ltd, 2011
    2011 RT Ltd. , Pearl White
    Jun 2019
    Farmingville
    2010 RT
    PM sent
    Mar 2013
    Maumelle, AR
    If you have the BRP part number go here: https://instructions.brp.com/e-instr...&sku=710004533
    You can print out the directions for the install.
    2020 RT Limited , Chalk
    Jul 2018
    Fountain Hills,AZ
    This link comes up as gps mount install...….
    Mar 2013
    Maumelle, AR
    Quote Originally Posted by wilpir View Post
    Yes. If you have the BRP part number put it in where it asks and you should get directions. On that page, scroll up a little and you'll see where to put it.
    Nov 2018
    Claremore, Ok.
    UtahPete sent the pics of his install. I put the Vent Kit on my 2015 and I'm VERY happy with the results. Now I don't get hot air coming up from the motor, and the Glove Box is cool enough that whatever you put in there isn't so hot you burn your hands. You don't need to cut a hole in the Tupperware, just remove the grill and everything will be hunkie dorie. Take all the parts out and fit them together on the kitchen table, they don't seem like they are compatable but keep trying until "The AH HA Moment". If there is a dealer near you that has been into Spyders from the git go, they might have the instructions in their files, ask, but remember the the Vents were for the 08-13 years. Good luck, and happy wrenching.
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
    Active Member Eviltwin's Avatar
    Oct 2017
    Portsmouth VA
    Quote Originally Posted by Revalden View Post
    I'm not sure about that. Part of the what the vents do is to funnel much more air through the engine compartment and to do that they need larger openings than were originally made on the panels.
    2019 BMW C650GT, 2010 Spyder RT-S, 2009 BMW R1200RT,(sold) 2009 Honda Silverwing (Sold), 2009 Kawasaki 500 Vulcan (Sold)
    2010 RT SE5 , Black
    Dec 2015
    Oakley Utah
    Quote Originally Posted by Eviltwin View Post
    2014 RTL Platinum
    Nov 2018
    Claremore, Ok.
    Just removing the grill has worked very well around here, Oklahoma, in 100 deg heat even in stop an go traffic. Do whatever you want.
    Tag-Along trailer
    Garmin 396 LM GPS
    New Banshee AGM
    Active Member scarecrow's Avatar
    largo, florida
    Live here in Clearwater Fl. added the vents to my 14RTS also didn't cut anything out. I just removed the grill vents. No problems and we spend alot of time in traffic. We'll see what happens in the summertime heat and humidity.
    2014 RTS , Cognac
    Nov 2018
    Claremore, Ok.
    Bring your Spyder over here to Claremore, about 30 miles north of Tulsa off of hwy 44 exit 255 then right on hwy 20 east, then right turn onto 4170 rd. your gps will bring you here. PM to me if interested.
    Tag-Along trailer
    Garmin 396 LM GPS
    New Banshee AGM
    Mar 2019
    NEBRASKA
    I did the same.Left panels intact. Place the scoops on top. Done.
    2012 RTL 14 RTS , Pearl White @ Pearl White
    Central Oklahoma
    2020 RT Limited , Petrol Metallic Dark
    Mar 2019
    NEBRASKA
    My dealer sold me the kit for $69 in 4 /2020 part # 219800388
    Aug 2020
    Germany
    Quote Originally Posted by sduskin View Post
    The link for the instructions does not work anymore.
    Is it possible, that someone could place the instructions again and link it here?
    Many thanks
    Michael
    May 2018
    Quote Originally Posted by WhiteCat View Post
    Many thanks
    Michael
    PM me your email and Ill send you the instructions.
    Eckhard
    Spyder RT Ltd, 2011
    Jan 2021
    MS
    Any way to get a copy of the install plans?
    May 2018
    Eckhard
    Spyder RT Ltd, 2011
