I called the dealer and they said the had the update and would I like to schedule a time to install. It took about 45 mins. As to how they got it...I did not ask, nor would I.
When the going gets tough...Downshift..
Update! Girlfriend and I went for a ride Sunday, I have an iPhone 7 and she has an android 8 active, we linked our phones and helmets with Sena 20s to the BRP Connect. Started out with FM radio, got the radio to come over both helmets, took several tries to talk to each other. Finally when we could talk, at first it tried to mute music and let us talk. That didn't last long. I had to mute the volume, then our Sena 20s, would allow us to talk. Switched over to music on my iPhone. Music in Driver helmet came right up, riders helmet had to be reconnected, took a few tries, finally got it to work. Same thing, had to mute to talk. Only one phone at a time on the system could take calls. I got a call with no problems, Girlfriend got a call and we didn't know it. Got tired of it so we disconnected from the BRP connect and resynced our phones and helmets.
The updated software made it a little better
Cruzr Joe
I am not sure if this is new. I have only had my spyder for a week. It has the 20.8 When in eco mode only it coaches you to raise the rpm if you are lugging it around. Right above the orange number that tells you what gear you are in an orange up arrow appears when in low rpm.
Is this something or not?
Dang the firmware updates....
Originally Posted by TheCajun1957
I think you will need the special USB cable. Dealer plugged in the usb cable and the normal BUDDS cable and it popped up. The Tech did say there was a notice stating the upgrade was available.
Ah....this morning I checked my 2018 and I have version 11.0 not even 13.0....and I just got it off the showroom floor two weeks ago....whats up with that???? Waiting on a call from the Service Supervisor at the dealer.... I might as well not even mess with trying to hook up the new Sena10S's I just got....
2 Wheels (ST1100, Marauder, Honda Shadow, Honda Rebel) 3 wheels (2018 Spyder RT Ltd)
Foam grip covers
Tri-Axis Handlebars.....
I think what you are looking at is the gear shift advisory whist in eco mode for economical fuel use not necessarily for a lugging motor,
Yours is the oldest update. Not much worked with 11.20 You need 20.8 Call your dealer. They should have done that before you picked it up. Demand they do it for free. You paid for that with the prep.
Thank you....been waiting all day for a call from the dealer Svc dept after I called twice...now 9:30 and no call...the longer they screw around, the madder I'm getting...
Foam grip covers
The same all over, too many customers, not enough staff. Sucks!
