Results 1 to 7 of 7
    Feb 2019
    Quebec
    Default LED Auxiliary Light
    Hi!
    On this guide :
    http://instructions.brp.com/content/...mber=219400848
    « Accessory housing » ... 12 volt connectors??? Add others options ?
    Type connector ?
    Thank’s
    Very Active Member Grandpot's Avatar
    Oct 2014
    Fort Mill, SC
    2011 RTS (Sold to a very nice lady)
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    SC Law Enforcement Boat Captain
    CNC Machine Service Technician
    President: Rolling Thunder SC1
    Member: Disabled American Veterans, Rock Hill, SC
    Member: American Legion
    Experience is recognizing the same mistake every time you make it!
    Dec 2018
    NY
    I think that if you. want to add additional accessories it includes an adaptor of some type so you can plug more than one connection. It appears there are spaces for three items
    2022 F3S, special series , Manta Green
    Aug 2015
    Crosby,Texas
    YES it all connect to each other.
    Jan 2019
    North Carolina
    It's interesting that in this photo, they suggest you plug in the connector to the middle housing.
    The handguard lights instructions suggest you connect that connector to the leftmost housing. I wonder what goes in the rightmost housing?
    2019 900 Rally Edition , Black w/Yellow Panels
    Active Member QuasiMotard's Avatar
    Jan 2019
    Houston, TX
    Quote Originally Posted by WilliamTRyker View Post
    I noticed the same thing in the docs when I installed my handguard lighting. I think it's just related to cable lengths and routing options... everything is daisy-chained from a single bike harness/connector. Also, keep in mind that this is a relatively low-amperage connection and you shouldn't run "heavy" accessories from that line. If you want to use it as an ACC tap, then you need to feed that through a power distribution block and/or relays to switch the heavy loads (e.g. large driving lights, heated gear, etc).
    QM
    Jan 2019
    Houston, TX
    Quote Originally Posted by Jsmith8695 View Post
    Each of the accessories has a male-female daisy-chain connection that allows you to link up multiple items. Everything is powered from a single accessory connector on the bike's harness, and then the accessories link to each other.
    QM
