Results 1 to 11 of 11
    Active Member TheCajun1957's Avatar
    Jun 2016
    Kilgore Tx.
    Default Belt Pressure - what is the manual spec?
    I understand this question has been talked about quite abit. My question is this. Can someone with a 2018 F3 Maintenance Manual, tell me what the manual says the belt tension should be set to.
    2018 White F3 Limited
    Quote Originally Posted by TheCajun1957 View Post
    Lots of info on this subject ….. Quite a few folks here have decided the OEM belt specs are too high ….. Those same folks have discovered , lowering it has removed most if not all the belt vibes ….. Using a Kritkit gauge I have my 2014 RT set at 160lbs. measured while it's on the ground …… Mike ...………..As far as the BRP specs for the F-3, they are only useful if you HAVE a SONIC gauge. Because that's what the specs relate to …..
    Jun 2016
    Kilgore Tx.
    thank you for the answer!
    Active Member RickWB's Avatar
    Jul 2019
    Duncan, British Columbia
    At 3000 miles, my F3 had its first service and the dealer adjusted the belt. I have bought ramps and will buy an oil change kit for next year to save the $400 dealer charge for service. If I buy the Kriket gauge, how often should I check it?
    Thanks,
    Rick
    2019 F3 base
    Shad saddlebags with Admore led light kit
    BajaRon swaybar
    Hopnel mini bra
    BRP driver's backrest
    Madstad windshield
    Ultimate floorboards
    CanAm Spyder accessories rear shelf with LinQ adapter
    Active Member ButterSmooth's Avatar
    Sep 2020
    Central Oregon
    Set it and forget it. It will announce when it needs attention by vibration. I check mine when rear tires are changed. Last check (tire change) started at 140# and I gradually increased the tension until the vibration stopped. I ended up at 205# measured by a Krikit II, or 172.5# measured sonically. You've got to find what works for you. YMMV and your Krikit (and technique) may vary.
    Head in the game, eyes down the road... 2020RT
    Spyder Tryke Pylot
    2020 RT , Lamonster extender Petrol
    Jul 2019
    Dealer equated motorcycle chain to Spyder belt, where chain is adjusted frequently. I don’t think this is true. I may just buy the Kriket gauge, an oil change kit, and do the work myself.
    Thanks
    2019 F3 base
    BajaRon swaybar
    Hopnel mini bra
    Madstad windshield
    Northern Kalifornia
    Quote Originally Posted by RickWB View Post
    Thanks
    Good decision. BajaRon can supply you with everything you need to do the job.........and more. As for the belt tension, set it but don't forget it. Just for safety reasons check it form time to time. About a 1/2 twist on the lower part of the belt with the thumb and forefinger is close to right. You'll get the feeling for it after you do it a few times.
    May 2009
    Connecticut
    I'm at 150 on my F3 and have 21'000 and No sprocket problem yet. No vibration. High belt tension has caused problems.
    Sea Doo GTI-SE 90 Jet Ski!!
    Active Member rugercharger's Avatar
    Apr 2019
    ohio
    for some of the people that have found their magic belt tension, are you measuring with the bike on the ground?
    Sep 2020
    Central Oregon
    Quote Originally Posted by rugercharger View Post
    The most successful process I've found is iterative. Start at a low tension (I use 140# on the ground), go for a test ride and then adjust both alignment and tension (usually tighten), and test again. Repeat until the belt is where I want it and there is no vibration. Then I measure the tension (just for the record) on the ground. Measuring in the air is irrelevant in this context. My belt alignment changes substantially between ratchet tight and torqued. The axle doesn't move, but the swing arm is 'sprung' out almost 1/4" wider than the axle is long.
    Spyder Tryke Pylot
    Active Member BMac920's Avatar
    Jan 2022
    The Woodlands, Texas
    Old thread, but thought I'd post regardless....I have a 2018 F3-L with about 2300 miles on it and on the ground I have a Kritkit gauge reading of about 150 pounds and a Gates Carbon Drive App for my iphone that read 22Hz,22Hz and 23Hz with an average of 22Hz, along with a picture of the rear pulley and belt location. The machine seems to be working fine and I now have two different measurements to reference in the future. I have no idea if the
    App is worth a hoot...but I have it! GLTA and Regards.
    Really good video : https://www.youtube.com/watch?v=pWGiCt7aW6s
    Last edited by BMac920; 02-12-2022 at 06:26 PM. Reason: Supporting video & photo added
