Page 2 of 2 FirstFirst 12
Results 26 to 34 of 34
  1. #26
    Feb 2009
    Ceresco, Michigan
    Quote Originally Posted by Micha. View Post
    We all have do to a measuring test drive in the 3rd gear. Start at 37 mph with flying start and measuring times from 50 to 75 mph. Compare the Times.
    My times with MaptunerX on my F3 2017 third gear from 60 to 140 km / h (37 - 87 mph). Stock Retracted stage 1. Stage 2 (K & N, Straight Shot ESD) not yet retracted.
    First measurement
    Default: 7:01 seconds
    Stage 1: 6:22 seconds
    Stage 2: 6:13 seconds
    Second measurement (slightly uphill)
    Default: 7:07 seconds
    Stage 1: 7:04 seconds
    Stage 2: 6:20 seconds
    80 - 120 km / h (50 to 75 mph) in seconds with a flying start
    Default: 03:25
    Stage 2: 02:29
    What method of clocking are you using? This would be pretty hard to be accurate without an accelerator of some kind to do the measurements.
  2. #27
    Oct 2015
    Germany
    Just using my ActionCam and the Timecode of PowerDirector 16.
  3. #28
    Feb 2009
    Ceresco, Michigan
    Thanks for posting, but I really don't think that's going to be very accurate.... especially when you're talking less than 1 second difference between your runs.
    Really would need to go to a track or use an accelerometer. There's some apps out now but I'm not sure how accurate they are.
    What model Spyder is this?
  4. #29
    Oct 2015
    Germany
    I have a F3-S 2017. I have no other way to "measure". The apps that are there are also not very accurate. Under optimal GPS conditions - GPS measurement at least 100 times in the second - this would be a bit more accurate. My smartphone can not do that.
  5. #30
    Jul 2019
    iowa
    Can you read and clear fault spyder fault codes?
  6. #31
    Florida
    Quote Originally Posted by spyderds View Post
    According to this, you can.
    http://www.powercommander.com/downlo...8200119.01.pdf
    2019 F3 Limited , Big Bike Parts full size pedal Black Metallic
  7. #32
    Sep 2014
    USA
    Yes you can
  8. #33
    Active Member 308gunner's Avatar
    Oct 2017
    covina california
    has anybody done a top speed run with the dynojet setup...I want to know did dynojet remove the speed limiter......I havent had anybody discuss this...
  9. #34
    Aug 2019
    Stoughton, WI
    Just received this reply back from Dynojet:
    Dusty Schaller (Dynojet)
    Oct 21, 10:01 AM PDT
    Currently we only offer 1 map for each device, stock improved. In the future you will see us develop more tunes for the PV3 and probably NOT the PCV. I would suggest you using the PV3 for this vehicle.
    Thanks for the inquiry. If you have any more questions please let us know. Thanks.
    2022 RT Sea To Sky
