Results 1 to 18 of 18
    Oct 2020
    dubbo
    Default belt tensioner position, top or bottom
    I am looking to build a belt tensioner for my RS. I have and extensive shop.
    I have trawled though all forums.learnt a little bit. Tensioner position never mentioned.
    I am wondering if having the tensioner mounted on the top run of the belt, the drive or tension side, is the best place for it. Surely the slack? in the belt would be in the bottom run?. Being the place to apply the tensioner?
    Your thoughts please people.
    thanks Paul
    Feb 2020
    N. Wilkesboro, NC
    I don't know anything about the RSs but the tensioner runs on the top of the belt on the RTs. Not sure how much engineering goes into a belt tensioner to determine the correct amount of leverage but I think I'd just buy one from one of our forum sponsors as they've probably done their homework.
    Active Member MNF3's Avatar
    Jul 2018
    Southern Minnesota
    Tensioner is a misnomer. It is actually a harmonic dampener. That is the reason it runs on the top of the belt, as that is where you are most likely to get the resonance. All of the solutions out there have the roller running on top.
    2016 F3-T , Intense Red Pearl
    Quote Originally Posted by paultt View Post
    thanks Paul
    IMHO, due to more than a few product failures, as reported on this forum ( which is likely to ruin the drive belt ). I won't use one - Period .... I lowered my belt tension to 160 lbs ( measured wheel on the ground ) and I no longer feel any Vibes at any speeds ..... good luck .... Mike
    Dec 2009
    West Oz
    Sep 2009
    La Valle, WI
    I've had a bottom one and top one. Top works better. I think a solid idler pully would work better like you see on automotive drive fan belts. With large heavy duty bearings. One on top and bottom. That would act as if the belt was half the size. Bet there wouldn't be any vibs at all.
    2018 F3 Limited , Oxford Blue
    Oct 2014
    Fort Mill, SC
    I've had top and bottom. I prefer top. Instead of using the small roller and bearing which by design rotate at very high rpm. I am using a timing belt pulley from a Hyundai Sonoma. It is 2" diameter with a very high quality bearing. It's been working well for several years.
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    Member: American Legion
    Sep 2009
    La Valle, WI
    Quote Originally Posted by Grandpot View Post
    Picture. Part number. Also does it fit the brp tensioner arm.
    Oct 2014
    Fort Mill, SC
    Quote Originally Posted by JP58 View Post
    I don't have a part number. It is a timing belt pulley from a 2005 Hyundai Santa Fe. Do not confuse with the serpentine belt idler pulley.
    1998 Honda Valkyrie
    US Navy Veteran
    Sep 2009
    La Valle, WI
    It looks like you have doc Humphreys tension arm on there?
    Oct 2014
    Fort Mill, SC
    Yes, I do. The roller and bearing now turn at half the speed as the original. The larger diameter, smooth roller doesn't whine as it rolls over the ribs on the old style belts.
    1998 Honda Valkyrie
    US Navy Veteran
    Active Member LifeLongRider's Avatar
    Aug 2018
    Florida
    I won't use one - Period .... lowered my belt tension to 160 lbs ( measured wheel on the ground ) no longer feel any Vibes at any speeds
    Same here !
    2019 F3 Limited
    2019 F3 Limited , Oxford Blue
    Jul 2017
    Woodbine, Iowa
    I sure wish you could come up with the part number or where it could be purchased.
    Asphalt Grey
    Lamonster RT phone mount
    Sena SMH-10
    Lamonster Belt Tensioner w/ larger roller
    Spyderpops Missing Belt Guard
    Garmin's GPS
    Maine
    I have been researching this and this is what I think. E-bay Pulley Idler FEBEST 1288-H1 OEM SMD 156604
    Quote Originally Posted by gerald37 View Post
    Part # for what? Sometimes it really does help to quote the pertinent part of the post you are replying to!
    Jul 2017
    Woodbine, Iowa
    Grandpot's post. Part # of the 2" diameter pulley from a Hyundai Sonoma.
    Asphalt Grey
    Sena SMH-10
    Garmin's GPS
    Jul 2017
    Woodbine, Iowa
    Quote Originally Posted by sandman53 View Post
    I did check Ebay and the roller looks like it might work.
    Asphalt Grey
    Sena SMH-10
    Garmin's GPS
    Oct 2014
    Fort Mill, SC
    Go to an autoparts store and tell them you want a timing belt tension pulley for a 2005 Hyundai Sant Fe with a 2.7L engine. You don't need a part number.
    1998 Honda Valkyrie
    US Navy Veteran
