Results 1 to 16 of 16
    Very Active Member eddieshep999's Avatar
    Oct 2010
    Broadstone,Poole, Dorset, UK
    Default Harley Trike - With Trike & Bike mode
    Found this on you tube
    https://youtu.be/jAbzBseEmwg
    Eddie Sheppard
    Poole Dorset UK
    Get a Spyder - See the World
    Nov 2013
    Oro Valley Arizona
    I do like that. Now I do not know if it has a reverse but if it does I could be sold one.
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Active Member Big Juice's Avatar
    Jul 2017
    Hot Springs Village, AR
    Well, as I see it, if you are in "Trike" mode, you're going to get hurt. Why, because with that narrow rear end it will tricycle over at a very low speed (notice how slow he is going in trike mode) because you can't lean into a curve or turn. Now in "Bike" mode, looks really cool! I personally would never ride it in trike mode at all. It's great if you want to sit on it stopped, but get it rolling and I'm getting off! But that's me, and I could be way wrong, but I'm sure not going to be the one to find out.......
    O. J.
    Ridin' "Lucille", the MusicMaker
    a 2017 F3 Limited (Pure Magnesium Metallic)
    Wife, Jan, riding "Ruby Jane"
    a 2016 F3-T (Intense Red Pearl)
    2017 F3-Limited , Magnesium (light grey)
    Interesting....I was going to say "and a leaner" but was not thinking about the fall over possibilities.
    Active Member Poseidon's Avatar
    Aug 2017
    Chesterfield, VA
    I only have one question... Why?
    The two rear wheels seem to give it a larger turning radius in bike mode than a 2 wheeled bike would have. The narrow rear makes it less stable than a true trike would be. Therefore, it does neither mode better than what it is trying to replace. Seems like nothing more than a novelty built simply to say it can be done.
    2016 F3T SM6 - Wife's Bike - Blank Canvas
    2017 Kawasaki Concours 14
    2016 Victory Magnum - Mods in progress
    2013 Suzuki M109R - Has a few mods
    Quote Originally Posted by Big Juice View Post
    Sep 2009
    La Valle, WI
    I would like the wheels to be wider apart so to be able to have saddle bags and have thinner tires. Then it would be more stable in trike mode.
    2018 F3 Limited , Oxford Blue
    Poseiden & Bob & JP...
    And while I'm here, it looks as tho it's only driving ONE of those dirty great rear tires too!! In the early part of the vid you can see the chain sprocket on the left & the end caps on each stub axle inside that/close to the centreline of the bike. So it appears that it's achieving its 'leanability' by using a left & a right swing arm up the back, only the right swing arm/tire doesn't seem to have any drive going to it at all!!
    Then when he gets the thing out on the road, it looks like he still hasta 'steer' it around the place & to stay in a straight line too, rather than balancing it straight then counter-steering & leaning it thru the corners like you would on a true 2 wheeler.... and to make things worse, it looks like he's gotta feed in a fair bit of steering effort to continually correct the bump steer & directional changes/corrections resulting from having just one driving wheel back there multiplied by the continual tracking changes those dirty great tires on the back end cause!!
    So really, apart from the actual leaning itself (which is sorta nice but IMO not essential), it looks like you get ALL the bad things about trike riding PLUS you lose most of the good things about bike riding! But I gues it does sound like a Harley & it looks pretty tough, so that'll probably make up for a lot for some!?!
    Jun 2014
    ny
    i like the backdrop, korean & chinese containers. is that a hint?
    Northern Kalifornia
    No brain bucket?
    Very Active Member oldgoat's Avatar
    DDO, Montreal Island
    I like it. Reminds me of the Piaggio MP3. Stay in bike mode until you are going very slow then switch to trike mode to support the bike.
    Just what I need but can't afford.
    2008 GS SM5, Full Moon Silver
    2007 Piaggio MP3 - 250cc
    Mar 2015
    forrest above Reno, Nv
    Any more lean than a few degrees and the undercarage will scrape and lever the " bike " up.
    2014 RTS , Circuit Yellow
    Northern Kalifornia
    At least half or more of us spyder pilots can't remember what it was that we went from one room into the other room to get, almost on a daily basis. How do you expect us to remember when to switch from bike mode to trike mode or back again? Suffering from CRS, this could lead to a catastrophe. I stopped buy the Can Am dealership last weekend and over heard a customer confessing to one of the employees that it took him several minutes to remember the spyder's starting sequence to fire it up and move it after he'd stored for the winter. LOL
    Nov 2018
    Northern NV
    Seems like a speed sensor input to shift from trike to bike mode wouldn't be that much of a problem. I'd be more concerned with the asymmetrical drive arrangement and the total lack of anywhere to put saddlebags or a tour pak. Solve those and I might have to go back to H-D... reluctantly!
    2017 F3T , Black, black and more black
    Very Active Member Big F's Avatar
    Aug 2012
    Bellevue, NE
    that was a really interesting concept of bike vs. trike mode. However, I still like the appearance of my Spyder RTL....
    BIG F
    Jun 2017
    Crossville TN
    Aint that the truth Went for a midwinter ride this year and that was the first thing I saud to the wife. If I can remeber how to start this thing
    Dave
    2013 RT Limited
    Lamonster FBB with larger gripper pegs
    Value Accessories dah mount
    Custom Dynamics High Mount brake light
    BRP passenger arm rests
