Page 2 of 2 FirstFirst 12
Results 26 to 39 of 39
  1. #26
    Nov 2018
    Claremore, Ok.
    That trunk-holder is more or less a stick.
  2. #27
    Nov 2018
    Claremore, Ok.
    Are you by chance thinking about the two screws that hold the seat in place? Those are problematic.
    To keep those square nuts from sliding out of the slot I put the bolt thru into the nut to hold it in place, then I put a dab of hot melt glue at the end of the slot.
  3. #28
    Quote Originally Posted by Revalden View Post
    Good fix! I used screws but don't remember exactly how without going out to look. I probably drilled a hole in the channel and put a screw through it to stop the nut.
  4. #29
    SF Bay Area
    Old thread but timely for me. Just got back from a long ride and would have been nice to have a tad more storage so got Big Bike Parts trunk carrier. Haven't used it yet but looks great and think it will work BUT trunk will no longer stay up. Would have been nice if they warned you so you can be prepared for the fix. Anyone else deal with this? Think I know what I need but if anyone has advice that would be great.
    Thanks.
    2014 RT-SE6
    Akrapovic Sport Touring 3C Silencer
    High Mount Third Brake Light
    Kuryakyn Black ISO Motorcycle Grips
    LaMonster Spyderdock
    LED’s everywhere!
    Russell Day-Long w/ Backrest
    Seal Floorboards
    Spyderpops Bump Skid
    Spyderpops KOTT Grill (Keep Out The Trash)
    Squared Away Alignment
    Riding taught me why dogs stick their heads out the window!
  5. #30
    Quote Originally Posted by martiniman View Post
    Thanks.
    Did you read this entire thread? The info you need is in the first few posts.
  6. #31
    Active Member Tatonka's Avatar
    Jan 2018
    North Carolina
    Like noted In previous ...Pierre at canamspyderaccessories.com....Simple unit e z to install
  7. #32
    SF Bay Area
    Didn't have time yesterday, but I will today, Thanks!
    2014 RT-SE6
    LED’s everywhere!
    Seal Floorboards
  8. #33
    SF Bay Area
    Quote Originally Posted by Purple Guy View Post
    I just bought mine from my dealer as I couldn't find a similar size and style in Canada and to order one from the US with the difference in the $$$ and shipping wouldn't have been cheaper.
    Gaz Shock - 708300383
    If you're mounting the second side as well you will need the mounting hardware as well
    Top Mount
    Spacer - 708300384
    Stainless Torx Screw,Nylon Patch,M6 X 30 - 250000398
    Domed Nut M6 - 232361493
    Bottom Mount
    Ball Stud - 250300039
    Hex. Flanged Elastic Nut M8 - 233281414
    Most likely operator error on my part, but I ordered the bottom mount parts, Ball Stud - 250300039 and Hex. Flanged Elastic Nut M8 - 233281414 but the nut was too big. Should be M6? Is the ball stud the correct size for the shock?
    Thanks for any insight you can provide.
    2014 RT-SE6
    LED’s everywhere!
    Seal Floorboards
  9. #34
    The nut should be M6. The ball is 10mm IIRC. I used a 10mm ball stud with 5/16" stud from NAPA when I added the second strut. Consider adding a fender washer under the ball to keep the plastic flange from bending from the stress of the strut. The upper end of the strut has a bushing. I found one close enough in inside and outside diameter from the hardware store and cut it shorter to fit. I think I got the struts from Lift Depot.
  10. #35
    SF Bay Area
    Excellent! I'll get another 10mm ball stud just to be sure. Thanks IdahoMtnSpyder!
    2014 RT-SE6
    LED’s everywhere!
    Seal Floorboards
  11. #36
    May 2018
    millsboro,delaware
    https://www.spyderlovers.com/forums/...6&d=1565870873
    Heres a link to the parts you need to add a second strut,just buy 2 of the smaller struts if you need to replace your original also.Theyre only 11.00$.If you want your seat to pop up easy also buy the large 16$ strut.Buy all the small hardware as well either way,its just like 3$ more.
    : 2017 RTL ORBITAL BLUE
  12. #37
    Member allcd88's Avatar
    Jun 2018
    Crawford NE
    Links for the parts are in the description of the video.
    https://youtu.be/Y4av0_tQvow
  13. #38
    Feb 2012
    Spring City,Utah
    Quote Originally Posted by spyder01 View Post
    I notice that the strut that you bought has a 5.9" extended length while the amazon replacement shock has an extended length of 7.87". how did you deal with the shorter length?
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
  14. #39
    May 2018
    millsboro,delaware
    I dont know why the amazon unit is so long,I do know that the unit I got from McMaster carr was about 1/8 inch shorter than the original on my 17rtl but made no difference to the operation of trunk lid at all except that the lid stays up easily even with a tour bag full of clothes on the rivco rack.My problem started when I put that rack on and the original single shock that was on it couldn't hold it up.I also felt that the shock for the seat was very weak so I changed over to the 40lb shock which now makes the seat pop up by itself,I just turn the key to release the seat and it pops up.Originaly my seat stayed up by itself until I put a BRP backrest on.
