Originally Posted by RudyB
Just had a new belt installed 2014 RTS to BRP specs always had vibration before now 0-80 no vibration
How many pounds tension does your dealer call "BRP spec?" Did he tell you?
It’s been proven there is no science too your method of checking the belt tension it’s your bike you can do whatever you want😉
Yes 1000 Newton’s off the ground no vibration anymore
Centramatic wheel balancers make a big difference you don’t have to worry about your wheels going out of balance again that is if you have 15 inch wheels
Ok where is this service tip to be found the thoughts on belt seem to be all over the map I have had a belt vibration ever since new just got e new belt installed at a BRP dealership set at mid range specs 1000 Newton’s off the ground I believe it’s about 230lbs vibration is gone so some are saying if Belt is too tight you get a vibration so at this point I really don’t care what the tension is the bike is running smooth everyone else can set their tension whatever their heart desires 😉
