Results 1 to 25 of 28
Thread: Spyder key
    Feb 2019
    Missouri
    Default Spyder key
    I'd like to put a key ring through the Spyder key. Is it possible to drill a tiny hole at the top of the key without hitting anything important? I've seen the key covers/holders, but was hoping this would be another solution.
    Oct 2015
    Lynden, WA
    Default Drilling a key
    Yes, I have drilled 1/8" holes in the top of both of my Spyder keys.
    I believe Finless Bob or Lamonster have posted how and where to drill the hole.
    I'll research my records and see what I can find.
    Here is the info. See post #4.
    https://www.spyderlovers.com/forums/...highlight=ring
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Feb 2019
    Missouri
    Quote Originally Posted by Haze View Post
    Great! Thanks for the info.
    Aug 2013
    SF Bay Area
    This is another option that doesn't require possibly damaging the chip in the key.
    https://www.amazon.com/Crazy-MetalMa...-1-spons&psc=1
    2021 F3 Ltd , Magna Red
    Nov 2017
    San Francisco Bay area
    Here’s what the prior owner did, works great and I just hang the keys around my neck.
    2015 Pearl White RTL
    Baja Ron Sway Bar
    Russell Day Long Seat
    Strobe Brake Light
    2015 RTL , Yes Pearl White
    Active Member Valkrocket's Avatar
    May 2018
    Murrells Inlet, SC
    Like that idea LC. Don't hafta worry about losing your key
    GLIDE-ON>>>>>>>>>>>>>>
    2021 RTL Chrome , Petrol Blue
    If you take a straight pin, and poke around a tiny bit near the top center of the key: you'll find that the hole is already there!
    Just take the drill bit with your hand, and open it up!
    I did this on my 2010 and 2014 RTs...
    Feb 2019
    Missouri
    That does look really nice. I may go that route. Thank you!
    The original sleeve the keys came with does work. Still am using the originals for both my 2011 and 2014.
    Nov 2018
    Denver, Colorado
    I have this key holder for my two keys...they are great. hold well are rugged.
    Northern Kalifornia
    I did what LeftCoast did for a long time and it worked well. I just always had that sinking felling that someday I'd go to grab my key and wouldn't be there. So, now I have a small carabiner with a small short chain holding my key and its retainer, that I can clip onto my front belt loop. The chain is long enough to allow the key and holder to reach down halfway into my front pants pocket, so if anything breaks, the key and the holder will all fall on into my pocket. I also carry an non-chipped key separately, so I can access the front and rear trunk and side bags if I ever lost the chipped key.
    Dec 2014
    S.E. Michigan
    I used duck tape around the key, with a hole for a split round thingy. Then I have a string to attach the key to a belt loop. I don't loose the key or leave it in the ignition when stopping. Not beautiful, but works. YMMV
    ~Sandee~
    ~Sandee~
    2016 RT-L (Purchased used in February 2018)
    RT Dash Mount (from JT's Spyder Store)
    Kuryakin Trident Highway Pegs
    Hopnel Pouch
    Magic Mirrors
    Spyderpops Foam Handgrips
    Iron Butt #35273
    Girls on Spyders #2779
    Greenville Tx
    We have those with the dark rope and a powerful magnet to detach the key for use.
    2017 F3 Limited
    I found a picture that may be useful for some of you...
    Nov 2018
    Denver, Colorado
    now that is some red neck engineering! love it!
    May 2018
    Jacksonville, Florida
    I had a little material and made my own key holder. A lot cheaper and are one of a kind.
    Thank you,
    Ray B.
    These are the states I have driven my Spyder Rt Limited too.
    Mudflap -- Walmart
    Tricled Headlights and Fog lights -- valueaccessories.comRimsavers -- RimBladesUSA.com
    Showchrome Tiregard (TPMS) -- motorcycleid.com
    Front and side grilles -- CanAmSpyderAccessories
    Passenger arm rest -- Diamond R Accessories
    Rear axle caps -- Lamonster
    Magic Mirrors -- Lamonster
    Yellow and red running and blinker lights on fender --Show Chrome
    TRUNK-MOUNTED, DOUBLE FLAG HOLDER -- Rivco
    Rear Brake light for trunk -- Custom Dynamics
    Bumpskid w/led lights -- Spyderpops
    Seat cushion -- Airhawk
    Cup holders -- Drink2Go
    Ultragard-4-457BK-Black-Cover-Spyder -- Big Bike Parts
    Cheaper than making a hole in the outer surface of the key??
    It's about a two minute job...
    Active Member ChicoFowler's Avatar
    Omaha, NE
    If you're caution about drilling into your key, try this: http://www.bigbikeparts.com/template...2&GroupGuid=78
    MotorcycleDave also sells them.
    Aug 2013
    Northern California
    We have worn our keys on a lanyard like Left Coast has for 62000 miles. My wife has my spare and I have hers. We never have a sinking feeling because the keys are always around our neck, not in a jacket locked in the frunk or on the road somewhere. The OEM key holder is really secure so I always know where my keys are! All the other contraptions pictured work too!
    And I don't worry about it at all! I just pull the key out of the ignition and drop it into my pocket! If I ever should lose it I will retrieve the non-chip key from behind the mirror, open the seat and trunk, and use the Torx driver to remove the passenger seat back. And there then in front of me is the chip spare key! A bit of a rigamarole to get to the spare but sure beats walking 20 miles to get another one! And there's nothing easier than just dropping the key into one's pocket. No lanyards, no carabiners, no key rings, no nuthin' to mess around with!
    Linden, CA
    I have them in stock.
    for a single key Gray color only $9.95
    for a duel pack in Black $18.95
    YOU DO NOT HAVE TO DRILL YOUR KEY.
    Ride Safe
    Dave
    Quote Originally Posted by Spyderman14RSS View Post
    May 2018
    Where can you get a non chip key?
    Thank you,
    Ray B.
    Mudflap -- Walmart
    Quote Originally Posted by Daddyray View Post
    Local key shop may have one, otherwise several sellers on Amazon or eBay. Look for Ilco X270.
    May 2018
    Thank you I will have to try that.
    Thank you,
    Ray B.
    Mudflap -- Walmart
