Results 1 to 21 of 21
    Member Bart's Avatar
    Mar 2017
    Kaysville Utah
    Default Seat and Frunk secondary releases
    Hopefully I'll never have to use them. Pretty simple to do and well hidden. Sorry about photos being all over the place. Still new to this, but you get the idea.
    2016 RT Limited
    Tri-Axis bars
    BajaRon Sway bar
    1970 Honda Trail CT70 fully restored
    2016 RT , Orbital Blue
    Active Member Boilermaker's Avatar
    Sep 2015
    Muncie, Indiana
    Good idea to do this as there are several who have had a problem with the releases. Many have done this with wire. You could search for other threads. I would be afraid the bungee would dry rot or break after being in the weather too long, but you do what works for you. Just make sure to keep an eye on it.
    Feb 2019
    AZ
    Sweet!!! Having locked my key in the rear trunk (You were there), having something like this would have been invaluable and saved sending a rider to my house for the spare key. Smart move, bro!
    Mar 2017
    Kaysville Utah
    Quote Originally Posted by Boilermaker View Post
    I didn't think about the potential weather for. I will keep an eye on it and go back to the original idea if I see it deteriorating. Thank you!
    2016 RT Limited
    Tri-Axis bars
    BajaRon Sway bar
    Mar 2017
    Kaysville Utah
    Quote Originally Posted by SpyderNomad View Post
    we won't be doing that again now will we? If only there was a way to do the trunk.
    2016 RT Limited
    Tri-Axis bars
    BajaRon Sway bar
    Jul 2014
    Mint Hill, NC
    If you buy an Ilco X270 key, have it cut to fit your Spyder, bevel it like in the picture, and keep it in your wallet or wherever you want to hide it on your bike it will allow you to do everything but start your Spyder.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Default Well done....
    Did a similar job (its out there somewhere maybe in my albums) but also always carry two keys with me. Have never locked myself out but you never know....
    ​2012 RS sm5
    Nov 2017
    San Francisco Bay area
    Unless it’s a non RTL thing how do you lock a key in the trunk? I need my key to lock it.
    2015 Pearl White RTL
    Baja Ron Sway Bar
    Russell Day Long Seat
    Strobe Brake Light
    Mirror Mount Turn Signal Indicator
    2015 RTL , Yes Pearl White
    Sep 2015
    Muncie, Indiana
    Quote Originally Posted by LeftCoast View Post
    The OP said frunk in his original post.
    Feb 2019
    Missouri
    On an RSS, if you lock your key in the frunk, just turn the handlebars all the way to the right. You'll see a cable with a small white piece of plastic around it. Gather up the slack of that cable into an L shape and give it a quick jerk toward the rear of the spyder. Frunk will pop open.
    Mar 2017
    Kaysville Utah
    My brother locked the trunk, but it didn't latch. He decided to take his coat off that had the key in the pocket, put it in the trunk and closed it again, this time making sure it latched.
    2016 RT Limited
    Tri-Axis bars
    BajaRon Sway bar
    Mar 2017
    Kaysville Utah
    I think yours was one of the threads I read that gave me the idea.
    2016 RT Limited
    Tri-Axis bars
    BajaRon Sway bar
    Mar 2017
    Kaysville Utah
    Great idea! I think I will do that. Thank you!
    2016 RT Limited
    Tri-Axis bars
    BajaRon Sway bar
    Nov 2017
    Quote Originally Posted by Bart View Post
    BWAHAHAHA. I shouldn’t laugh but the thorougness the 2nd time around explained it. Glad it worked out ok.
    Baja Ron Sway Bar
    Strobe Brake Light
    Bossier LoUiSiAna
    & enine HEAT if it does snap while running is there any chance it will fall into something moving be safer & swap out with a solid wire that will stay in place
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Active Member Nobodyjj's Avatar
    Sep 2018
    Caledonia,Ontario,Canada
    Use steel cable fishing leaders, various lengths and strengths available. Fittings on each end to connect.
    Jan 2015
    southern WI
    Coming up with secondary openings in the compartments is on my spring to-do list. Right now it's snowing and 10 friggin degrees.
    2021 RT Limited
    2016 RTS , Pearl White
    Mar 2017
    Kaysville Utah
    Nope, never even considered the heat factor either, thank you! I have some wire, but not sure if I like it for this, thats why I didnt use it like I initially planed. I may look into what nobodyjj used.
    2016 RT Limited
    Tri-Axis bars
    BajaRon Sway bar
    Bossier LoUiSiAna
    & some how mine didn't need the beveled corners also made a DIY card size holder out of coroplast to help hold in place in wallet IMG_5800.jpg spares pulled out slightly for show the blade fits in the coraplast holes with minor cutting for head of the keys. Another other option is securing one on the bike unseen but accessible, say ziptied to something under a easily removable panel. Or go Old school & lace into shoelaces ( but It works)
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    SENA 20S EVO
    Mar 2017
    Kaysville Utah
    Excellent suggestions, thank you!
    2016 RT Limited
    Tri-Axis bars
    BajaRon Sway bar
    Dec 2014
    S.E. Michigan
    I prevent this by tying the key to me. Saves the battery from me leaving the on.
    ~Sandee~
    ~Sandee~
    2016 RT-L (Purchased used in February 2018)
    RT Dash Mount (from JT's Spyder Store)
    Kuryakin Trident Highway Pegs
    Hopnel Pouch
    Magic Mirrors
    Spyderpops Foam Handgrips
    Iron Butt #35273
    Girls on Spyders #2779
