Results 1 to 5 of 5
Thread: sensor location
    May 2018
    virginia cape charles
    Default sensor location
    where is the sensor located that changes the lcd screen
    2021 f3l , large pedal pad and lamonster lowering rod liquid titanum
    Nov 2012
    North Las Vegas, NV
    Depends what you are riding. Our 2016 F3L has an option under "mode" to keep the night screen on. After checking on this the only option I have is the contrast amount for night or day. With your spyder in a dark garage turned on and the night dash showing, use a narrow beam flashlight to locate the sensor and use a piece of black tape to cover it.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Oct 2014
    Fort Mill, SC
    For an RT, it is near the speedometer and tachometer. Once you find it, a piece of black electrical tape can cover it. I assumed you were asking about night/day.
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    Member: American Legion
    Sep 2016
    Chillicothe, Oh.
    I tried the piece of tape trick. It doesn't work unless you cover so much of the display that it becomes useless.
    2015 RT , Black
    It helps if we know which model year RT you have...
    On the 2010 to 2017 models: it's at about the 10:00 position on the Analog Speedometer... but you WILL end up covering up too much of the gauge, for this to be truly useful...
