Results 1 to 6 of 6
    Active Member MDBrion's Avatar
    Feb 2016
    Southern Maryland
    Default 2014 RTL Digital Display Question
    Hi Folks, we recently purchased a 2014 RTL SE6 and the digital display has an orange background... I’ve seen other photos that show the same digital display on the same model year with a white background and yet I can’t find anything about changing it or what the significance of the display color might be.... Any insight appreciated !
    Just cause you got the monkey off your back doesn't
    mean the circus has left town.
    - George Carlin
    Hollywood, Maryland
    2015 F3S, SE-6
    oem backrest, oem saddlebags, F4 Customs windshield, oem fog lights
    2011 RSS, SE-5
    Handlebar Riser, Heat Wraped exhaust, Power ports int./ext., 23" touring windshield, Led brake lighting strips.
    2014 RTL , Black
    Feb 2016
    Southern Maryland
    Ok, I think Im able to answer my own question... seems the digital display will use a light color when the ambient light is bright and change to a darker color when it gets darker out.... the orange background scared me... I thought it was an indication of a problem. All is well !
    - George Carlin
    Hollywood, Maryland
    2015 F3S, SE-6
    2011 RSS, SE-5
    2014 RTL , Black
    Active Member Joerolwing's Avatar
    May 2016
    Nashville, TN
    Glad you picked up on this so quickly. Right after I purchased my 214 RTS SE6 I headed west towards Prescott, AZ. I hit the road about 5am the next morning and my only thought was that I had that “dreaded orange screen” but could find no error code number. I slowed down until daylight when the rising sun finally figured it was simply an IO problem (Idiot Operator). I had a really enjoyable trip after this.
    May 2018
    virginia cape charles
    where is the sensor located
    2021 f3l , large pedal pad and lamonster lowering rod liquid titanum
    Sensor is in the speedo. Try about the 10 o'clock position. Some people have covered the sensor with black tape so they can use the orange color full time.
    The idea was to have the color change for nighttime driving. I have only had the night time ops go on one time here. We don't ride at night...which can be 3:00 AM here in the great white north.
    Quote Originally Posted by MDBrion View Post
    Glad to hear tha you sorted it all out!
    By the way: where'd you get that picture of me for your Avatar?
