Rally Suspension Settings
Just wondering what setting others are using on their rally. My rally came with front set at 3 and 3/4 inch of preload on rear shock and damping on 2. I weight 150 pounds and was thinking of trying different adjustments to see what I like. What size spanner do I need for the rear shock ?
On a related note, my rally does not appear to have any damping on either compression or rebound. Seems like only the spring is working. This is only on the back. Front seems to be working properly.
I weigh about the same as you. I changed the preload in the front to 2 and in the rear to 1/4 inch and compression damping to position 2. The result was much less front wheel hop and overall more comfortable ride. Body roll in turns is still fine. For the rear shock I used this. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Tslepebull , thx you ....that was the info I was looking for. Will try your setting when I get the spanner.
I wonder if that tool will adjust the rear shock on the regular 600's and 900's?
