Page 2 of 2 FirstFirst 12
Results 26 to 30 of 30
  1. #26
    Quote Originally Posted by Eckhard View Post
    The closest metric size to a 1/4 " washer is a washer for a 6 mm screw. 10 mm refers to the hex wrench/key size for the hex head on a 6mm bolt.
    Thanks ….I corrected my error …. Mike
  2. #27
    Jul 2011
    Mitchell, Ontario, Canada
    Normally I would suggest getting the battery load tested first. But in your case just replace it with the correct one. It's too small and that will show up when it is cold. Just as you are experiencing. The battery you have now has a CCA of 240 amps. That is at room temperature. I would guess it maybe not much higher than 120 at 20 degree F. As for brand. I would get another OE battery which are the Yuasa brand. Good quality and a reasonable price.
    2018 F3 LIMITED
  3. #28
    Active Member cenzo989's Avatar
    Apr 2016
    Staten Island, NY
    ultimately....i think im just going to purchase a new battery.....
    ThNK YOU FOR ALL YOUR INPUT GUYS !!
    i really appreciate it
  4. #29
    Quote Originally Posted by cenzo989 View Post
    Your welcome ………..However get the correct SIZE battery ………… Mike
  5. #30
    Linden, CA
    New Battery time.......
