Results 1 to 21 of 21
    Nov 2011
    charlotte,nc
    Default Rear wheel bearing funny nut stuck.
    I have tried the park f6 tool and a crow bar. That funny nut not moving. Is there anything else I can use? What am I doing wrong ughhhhhh
    Jul 2010
    Las Vegas, NV
    We found a wrecking bar fits perfectly.
    Joe Meyer
    Aug 2013
    SF Bay Area
    Are you using a cheater bar? If anything, go to Home Depot and buy a 3' piece of metal plumbing pipe and use it to lengthen the wrench. Make sure the bearings need to be replaced. After I did mine I found the OEM ones were fine.
    2021 F3 Ltd , Magna Red
    Nov 2014
    Mountville, PA
    A 5-sided freakin' nut?? Why in the name of all sense would anyone do that except to force the owner to either purchase a special wrench or to force him/her to have an authorized shop do the work?
    Active Member cbredneck's Avatar
    May 2013
    leesburg fl, Kent Island Md
    Quote Originally Posted by kep-up View Post
    look again
    [SIGPIC][img]https://www.spyderlovers.com/forums/maps/map.prov.png?states=[img]https://www.spyderlovers.com/forums/maps/map.prov.png?states=BC.ABhttps://www.spyderlovers.com/forums/maps/map.prov.png?states
    Houston
    There is no 5 sided nut.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Dec 2015
    Oakley Utah
    Quote Originally Posted by NVERLAST1 View Post
    Is it a reverse thread maybe?
    2014 RTL Platinum
    Oct 2014
    Fort Mill, SC
    It's a normal right hand thread. As Cptjam suggested, a wrecking bar or something similar that can be wedged between two opposing slots will work.
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    Member: American Legion
    Dec 2015
    Oakley Utah
    Like this?
    2014 RTL Platinum
    Oct 2014
    Fort Mill, SC
    Like this?
    Yes. Put a large wrench on it and turn.
    1998 Honda Valkyrie
    US Navy Veteran
    Dec 2015
    Oakley Utah
    Quote Originally Posted by Grandpot View Post
    Can you explain how to 'put a large wrench' on the wrecking bar? I'm having trouble visualizing this technique. Thanks.
    2014 RTL Platinum
    Very Active Member AeroPilot's Avatar
    Nov 2012
    Pueblo Colorado
    More like a big A__ crescent wrench slimmed down to grip the flat width of the pry bar that is stuck into the slot of the regular threaded nut.... if you do this more than a few times, grind a custom fit piece of flat stock about 1/4 inch thick to fit...DSCN2810.jpg
    07 Shadows, Aero, Spirit gone but not forgotten
    03 Harley Sportster, 07 RK moved on
    11 RT- 76,000 mi, 15 RT-S- 44,000 mi, traded for current 15 base RT and 16 F3T
    2015 RT , OEM Black Gloss
    Dec 2015
    Oakley Utah
    Quote Originally Posted by AeroPilot View Post
    And, how does this grip the nut?
    2014 RTL Platinum
    Dec 2015
    Oakley Utah
    Okay, so the picture above shows the Park Tool FR-6 in place. Park Tool FR-6_001.jpg
    Now, I'm understanding the issue better.
    Why not use a breaker bar with the right sized socket on it? Or, as mentioned, slip some steel pipe over the socket wrench handle to provide additional leverage.
    I still don't understand how you would use a wrecking bar to turn this nut...
    2014 RTL Platinum
    Oct 2014
    Fort Mill, SC
    The straight end of the bar goes in two opposite slots in the nut. Get something to use to apply torque to the bar. I don't know how else to explain it.
    1998 Honda Valkyrie
    US Navy Veteran
    Nov 2014
    Mountville, PA
    Don't teach cursive in school now, and didn't teach countin' waaay back when I was larnin'.
    Nov 2012
    Pueblo Colorado
    Default Well...
    ....first the pry bar trick is for those of us too cheap ( I mean frugal) to get the right tool....then when the Park tool is out of the way or not available,,
    just hold the flats of the pry bar in the slots of the retaining nut like GranPot says... helps if you hold your mouth right.. and use that big Crescent wrench
    to twist whilst you hold down to keep the pry par ends engaged in the slots... Well on second thought probably you should just go buy the right tool and
    the proper socket along with a 24" breaker bar and get after it but like others said, don't change it if you dont have to...
    We have put over 40 K each (76, 44, 46, 40) on four different bikes, and always feel and spin the bearings when we change tires, and havent changed a bearing yet...I do have a set on the shelf waiting
    Dec 2015
    Oakley Utah
    NOW I get it. You use the pry bar INSTEAD OF the freewheel tool. That makes sense. As far as the OP goes, he DOES have the freewheel removal tool and just needs more leverage on its nut in order to break free the freewheel bearing retainer nut.
    2014 RTL Platinum
    May 2018
    Chateauguay, Qc, Canada
    Would you care to share the model number of those bearings.
    Eckhard
    Spyder RT Ltd, 2011
    2011 RT Ltd. , Pearl White
    Jul 2010
    Las Vegas, NV
    Use the short arm of the wrecking bar. See post 12. Not the end he has a wrench on: the other end! Fits perfectly. Regular thread. I stand the wheel up, nut side on right, insert bar, push down.
    Joe Meyer
