Results 1 to 15 of 15
    Active Member Leadfoot's Avatar
    Jan 2019
    Bell, FL
    Angry Passenger seat Installation problem
    I can't get the seat to slide far enough back for the lock to engage the frame. It's about 5/8" forward of where it needs to be.
    Anyone had this problem and solved it?
    Nov 2018
    N.E. Ohio
    I wouldn't know because my passenger seat has been on "back order" since December. cueman
    Active Member njfishfan's Avatar
    Dec 2018
    New Jersey
    Got my rally 3 days and have no problem with passenger seat install....I do have the passenger comfort seat with adjustable backrest
    Jan 2019
    Bell, FL
    Got mine on after several hours of careful grinding on the mating surfaces of the seat and frame. The final .003" of needed clearance was made by removing the weight warning sticker on top of the seat mount. It was still a very tight fit. I was not impressed with the "snap on snap off customizability" of the Ryker! But it is a blast to ryde.
    Mine was the standard passenger seat with the folding backrest, don't know if the comfort seat fit might be different.
    Feb 2019
    England
    Hi all ref fitting tight passenger seat , mine is the same a good hard shove got it off Then a small file on the plastic bits where it mates with mount did the trick But I still have to knock seat back , but it's better regards Nico75
    Nov 2018
    N.E. Ohio
    I sprayed the seat and bracket with silicone spray then sat on seat and used pegs to push back. cueman
    Jan 2019
    Bell, FL
    Guess I still need to do more grinding and filing on mine. The lock keeps popping up while riding. Smacks my girlfriend right in the p.., groin, every time.
    Active Member mikeyuberalles's Avatar
    Feb 2019
    Clearwater, FL
    Quote Originally Posted by Leadfoot View Post
    I would expect that they would charge extra for that feature.
    Mar 2019
    Austin, Tx
    Push it on dont pull, works easy that way.
    2019 Rally , Black
    Jan 2019
    Bell, FL
    Pushed hard enough to punch a hole in the front : )
    Mar 2019
    Austin, Tx
    Push forward and down
    2019 Rally , Black
    Nov 2018
    N.E. Ohio
    Read #6
    Jan 2019
    Bell, FL
    Quote Originally Posted by thechamp73 View Post
    Mine comes off that way.
    Florida Swamp
    Not saying this is the problem, but it might be worth looking at;
    https://www.motorcyclistonline.com/c...system-failure
    By the way, I am not more than 40 miles from Bell.......... rode through there many times. Got a cousin lives on the river down there.
    2019 F3-S , Black & Silver
    Active Member bcraig's Avatar
    Grove City, OH USA
    I had the same problem until I realized the front lip of the passenger seat needed pushed down as it was slid back.
Tags for this Thread
