Results 1 to 10 of 10
Thread: Throttle adjust
    Feb 2019
    Western PA
    Default Throttle adjust
    We just got a 2015 F3-S / SE6. Tonight was the first time I ever rode a Spyder. Didn't know it wasn't a cable throttle. I assume there is just a spring in the twist grip which has a very light touch. Is there a heavier spring or whatever mechanism they have in there that you could buy to make a heavier feeling throttle? Thanks.
    Nov 2016
    Upstate NY
    The return spring is actually in the end of the grip, or so i have read. The parts schematic shows the spring but not the sequence that it is installed. I suppose you could remove it and find a suitable spring. I have heard they can be tricky to reinstall.
    Feb 2019
    Western PA
    Quote Originally Posted by Joel The Biker View Post
    I appreciate the heads up.
    I suggest you don't muck with it. There are threads hereon about folks having problems when they've removed it while trying to do something else on the right side of the bars. The light touch can be less fatiguing for someone who rides a lot but doesn't use cruise control.
    Active Member Boilermaker's Avatar
    Sep 2015
    Muncie, Indiana
    At my first service on my 2015 RTS, I asked the dealer to check the throttle because it was touchy and would not return firmly when decelerating. The dealer found that my throttle spring was installed backwards from the factory. Probably not your issue, but just something to keep in mind.
    Feb 2019
    Western PA
    Quote Originally Posted by Boilermaker View Post
    Thank you for the heads up.
    Active Member wingit3611's Avatar
    Dec 2016
    Louisville, KY 40214
    Ditto on the spring in the handle. I had mine out and didn't think I'd ever get it back rite. Turned out I was over tightening it. TRICKY
    Can Am 2013 RTL SE5
    Very Active Member spyderCodes's Avatar
    Jan 2016
    PA
    A 12 dollar spring shouldn't lose its tension under normal use.
    It may be installed backwards or improperly as was suggested by others.
    The throttle should be, for safety's sake, a deadman type that rapidly returns to closed when your hand isn't on it.
    If I didn't feel as if it was something I wanted to tackle, I think I'd bite the bullet and take it to a dealer.
    The Power of Logic.
    Start Thinking.
    May 2017
    Mesa, Arid-Zone-A
    It should snap closed when released. If it doesn't then the spring needs attention. If it just seems lighter than you are used to, I would ride a bit and see if you don't get comfortable with it. Reading your other thread, I believe this bike is for your wife.....? If so, make sure she likes the way it responds before you do anything she will regret. And, welcome to SLs..... Jim
    Semper Fi
    Feb 2019
    Western PA
    Quote Originally Posted by canamjhb View Post
    Thank you.
