Results 1 to 7 of 7
Hybrid View
    Feb 2016
    France
    Default Rear Wheel Bearings
    Does anyone have any old RT rear wheel bearings, if so is there a number or letters and numbers stamped on them, if so can you tell me these numbers.
    The reason I ask is I am told by a bearing specialist that all bearings have a number that relates to therir size, the number is intenational so whatever number you buy in whatever country, that is the size.
    My RT has done 40,000 miles and I want to be prepared. I would like to use SKF bearings that are reputed to be the best in the world.
    Whatever bike or machine I have had I have found this number system to be true, I order by number from said bearing specialist in UK and up comes the correct bearing every time, of whatever make or quality I want.
    Had my wheel out last week for new tyre, but bearing numbers were stamped on underside so not visible
    Alex
    2014 RT Std
    Floor and Highway Boards
    50$ GPS connected to oem loom
    Trunk & Frunk Liners and lights
    Frunk and dashboard power outlets
    Front supension LEDS
    Cup holders
    Glovebox light
    Turn signal LEDs in mirrors
    12 volt coffee maker
    Passenger hangrip muffs
    Ignition lock light
    Windscreen wiper/ baguette holder
    If I wasn't so cleverI wouldn't need to be so good looking.
    2014 RT , Black
    Oct 2014
    Fort Mill, SC
    I could not find a number on my bearings. The seal is from NSK, but that does not mean they are NSK bearings. I deal with NSK all the time and they always have the part number on the bearing races.
    The best thing to do is take the bearings to a bearing distributor and have them match the bearings to the NSK or SKF equivalent. That's what I plan to do next time.
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    Member: American Legion
    Dec 2009
    West Oz
    All 3 bearing can be purchased from a bearing supplier but the hub seal are an odd size and only genuine will fit -p/number 293200094.
    The wheel takes 2 of 6205-2RS bearings. Three O-rings 15x3mm needed (can't remember what for exactly) and one 60x3mm. The pulley takes a 5006-2RS bearing and you may also need Loctite 660 plus Loctite 7471 primer/accelerant if any of the bearing aren't tight in the bore where they sits.
    Oct 2014
    Fort Mill, SC
    Just to clarify, the seal I mentioned was the seal on the sealed bearings themselves.
    1998 Honda Valkyrie
    US Navy Veteran
    Feb 2016
    France
    Thank you very much, just the information I am looking for
    2014 RT Std
    Cup holders
    Glovebox light
    Ignition lock light
    2014 RT , Black
    By the way: SKF bearings ARE pretty damn good!
    Happy hunting!
    Default Rear bearing
    This may not apply because my Bearings packages dates are in 7/13 !!! …. one package rear bearing is stamped U.S - NSK …..part # 293350065 ( NSK on the seal also )….. I believe all Spyder 15inch wheels have the same rear bearing …..the only marking on the bearing inside RACE itself is " .UR " ...stamped on the SEAL is 30BD40DF2 ( not easily read !!!% may not be correct ) ………The NEW front bearings I have are for 14inch wheels ( the new 15 inch may be different …… Part package # 29335055 ...on the bearing seal is #6205DU2 NSK made in China ... .. good luck …. Mike
