Results 1 to 25 of 40
    May 2009
    Connecticut
    Default Ryker Comfort seat installation?
    Shawn shows lifting front end to install Comfort Seat OTHERS on Facebook say its a 2 minute pop off and pop in job?
    Whats the story and can anyone give instructions from experience OR a short video.
    BRP should have a short video on this like they do for many other add ons!!!
    Sea Doo GTI-SE 90 Jet Ski!!
    Jan 2019
    North Carolina
    Quote Originally Posted by Sarge707 View Post
    The docs show lifting the upper body module as step 1. That seems like it's more than 2 minutes...
    2019 900 Rally Edition , Black w/Yellow Panels
    Aug 2015
    Crosby,Texas
    Default Selling a rally seat
    Anyone wanting to sell a stock rally seat ? PM me if you do. 3.15.2015 update: GOT ONE. THANKS
    Default Little checking.....
    I seem to remember a Smoak video where you have to strap the tank and have a support for the upper section. He said there was a special tool but he used a cut 2x4. He did say it was all fairly easy....
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    May 2009
    Connecticut
    Hopefully Shawn will do a video with a "Little More Detail" on the subject- I Love his blog videos.
    Mar 2019
    NC
    I'd be interested to know if there's more information on this. Just picked up a comfort seat for my Ryker 600. Don't have a shop manual yet...
    Jan 2019
    Pittsburgh, Pa
    Just put mine one week or so ago. Just grab the back of the stock seat and lift up hard , it will pop off and the new one just pushes on.
    Mar 2019
    Oregon
    I just bought my wife a new Ryker Rally this weekend...
    Wow, lifting the upper frame/assembly seems a bit ridiculous. You'd need to remove most of the fairing components to do so...
    Here's how I installed my wife's seat:
    1. Remove the 2 T20 screws securing the back of the pan to the frame assembly (in the wheel well).
    2. Pry up on the back of the pan (by hand) and wedge something in between the pan and frame assembly to create a small gap; do this on both sides.
    3. With the pan slightly elevated from the frame, pull off the old cushion; it's held in place by 4 foam tabs that are compressed between the pan and frame.
    4. Install the new seat by manipulating it onto the pan and pushing the foam/rubber tabs into the pan holes.
    5. Remove the wedges and ensure that the seat feels secure.
    6. Replace the T20 screws and tighten them down.
    IMHO, this is some horrible engineering. Anyone can remove and steal the seat by forcefully pulling up on it. If the foam were secured to a metal or plastic bracket, it could have been secured from the underneath by screws.
    Jan 2019
    IL
    I installed the comfort seat, by just pulling up on the back of the original seat, put the comfort seat down and pushed down, basically sat on it with my body weight to make sure the tabs snapped into place. None of this lifting the body up. Took all of about 3-5 minutes and that was including the wife checking out her new seat.
    Jan 2019
    North Carolina
    I just had the dealer install my comfort seat and the helmet bag/lock. Now, the important question: What do I do with the old stock Rally seat?
    2019 Can-Am Ryker 900 RE
    Very Active Member Rogue Hawk's Avatar
    Apr 2015
    Chicago
    Well, that gives me comfort
    2019 Rally , Black
    Mar 2019
    Oregon
    Quote Originally Posted by WilliamTRyker View Post
    I'd save it for when you sell the bike. Put the original seat back on and sell the comfort seat by itself. Also, some custom seat shops require the stock pad for their services. Save it in case you want to have a custom seat made.
    Mar 2019
    NC
    Just wanted to update to this, and say that the comfort seat installation was stupid easy on the 600. Just pull the old one up, and push the new one on. Easy.
    Mar 2019
    Lakeway, TX
    Yup just pull the old one up and push the comfort in, 2 minutes job.
    Mar 2019
    New Mexico
    I have a question on this seat installation. I've got a 600 with the seat spoiler attached. Do you need to remove the 2 screws holding the spoiler on before lifting the original seat to install the comfort seat? Thanks in advance.
    Jan 2019
    IL
    Quote Originally Posted by mugwomp View Post
    Mine is a 900 that has that Seat Spoiler, did not have to remove anything...Just pulled up with a good tug.
    What I did with my two RT OEM seats. Put one on the shelf in 2012 and the other on the shelf in 2015. Both replaced with BRP Comfort seats. Now that I am in the process of moving...one went out in the garbage today and the other will go out in the garbage next week. No market for used, and the shipping is over $150 to the lower 48. For me...a sunk cost and not worth moving.
    Nov 2018
    hudson michigan
    I just pulled mine off on wed. to put a airhawk cushion on and when I went to install I can't get it to pop back on. Has anyone done a video on how you pop it back on? I've pushed on it, hammered it with my fist, put my 285 lbs. butt on it and jumped up and down on it and all I've done is rip one of the foam tab off. Tomorrow I will try lifting the pan and going that route. Any advise is appreciated. Farmer54
    Dec 2018
    NY
    I remember looking at the BRP instructions on line. They used 'BINDER Clips to squeeze the tabs on the bottom. The clips need to be small enough to fit through the holes in the seat pan. Just remove the clips once the tabs are through the holes to expand the tabs
    Current: 2022 CAN AM F3S SS. Manta Green, Route 129 windscreen.
    Previous:CAN AM Ryker Rally. Intense black, side case , comfort drivers seat, comfort passenger seat with back r test, wind screen, LED auxiliary lighting.
    2022 F3S, special series , Manta Green
    Hanover, PA
    I watched the dealer change the seat and they just pulled the stock one off by hand and popped the comfort seat on. 30 seconds tops. They did say it was harder to put the stock seat back on though because the little rubber ears are different on it and don't want to go into the slots.
    May 2009
    Connecticut
    Well I have 1500 miles Now and the Rally seat with sheepskin is OK for 90 miles BUT is the Comfort seat worth it for those of you who have had BOTH??
    Is It WORTH the $300????? OR would you have waited for a Aftermarket seat?
    Nov 2018
    N.E. Ohio
    I have the Rally and it is fine for hours in the seat. Everything else hurts but my rear end. cueman
    Jan 2019
    Oklahoma
    Hey, Sarge!
    I snapped my Comfort Seat on my Rally last night.
    It literally took 2 minutes, and 1 of those minutes was getting my nerve up to just rip the old seat off!
    I went on a 20 minute ride and, to me, it felt quite a bit more comfortable.
    The shape fits my expanding butt better than stock and I like the looks considerably more as well.
    In my opinion it was well worth the $300.
    Jan 2015
    washington
    Default That's funny
    Quote Originally Posted by OregonLAN View Post
    perfect. That's funny, I did this very thing last night, I could have written this myself.
    Kansas
    You must have a different Rally and Comfort seat than I do. No need to remove any screws, just pull the old seat off. The tabs on the comfort seat aren't foam they are plastic. The stock seat seat has foam tabs but not the comfort seat.
