Page 2 of 2 FirstFirst 12
Results 26 to 40 of 40
  1. #26
    Mar 2019
    Oregon
    No, I have the same comfort seat. The comfort seat has plastic clips that hold it in place. It simply pops on. The stock seat has foam/rubber tabs that hold it in place. You can rip it off, but you risk damaging the seat. To reinstall it, you must lift the pan.
  2. #27
    May 2019
    Washington
    The comfort seat looks great but will it hold up to rain and the elements?
  3. #28
    Active Member cheska's Avatar
    Apr 2013
    Vancouver Is. BC /Arizona
    Hi question: Is the comfort seat thicker? Wife nees to sit up higher. We tried a sheep skin and a air hawk seat cushion, neither were thick enough.
    900 Ryker Wifes
  4. #29
    Active Member bcraig's Avatar
    Grove City, OH USA
    Quote Originally Posted by cheska View Post
    I haven't noticed it being thicker or sitting higher.
  5. #30
    May 2009
    Connecticut
    Quote Originally Posted by bcraig View Post
    Is the foam padding better. I'm just Concerned before I spend $300- Is it worth it for a 2-3 hour normal ride???
    Sea Doo GTI-SE 90 Jet Ski!!
  6. #31
    Grove City, OH USA
    Quote Originally Posted by Sarge707 View Post
    Don't know about foam thickness, but it is more comfortable.
  7. #32
    Active Member vstrommer's Avatar
    Oct 2015
    miNNESota
    I’m waiting for Corbin or Mustang to get one out. BRP foam density is way toooooo soft for any long time spent in the saddle.
    2019 900 Rally , Black
  8. #33
    May 2009
    Connecticut
    Dealer gave me a Deal ($255 plus Tax) for the Comfort seat and it indeed just snaps in without a problem. Just sat on it and it feels wider without the BIG rear hump but won't know till I ride. Wondering if there is a Market for Used Rally seats as they have about 1 inch thicker foam than the 600/900? The person buying would have to figure how to get the foam tabs in the seat base because it seems you would have to lift the seat pan to do. I see one on Ebay now?
  9. #34
    Very Active Member Tslepebull's Avatar
    Dec 2018
    East Texas
    After 8 months on the Rally seat I finally ordered the Comfort Seat on line. The Rally seat was OK for about an hour but my butt got sore after that. I am a skinny build with little between my pelvis and the seat but skin. For me the Comfort Seat was worth every penny and has extended my comfort level to -- well, I don't know yet because I haven't ridden long enough without getting off of it to find my limit. My question is why BRP put anything but the Comfort Seat on it? If you have something that feels that good and instead you deliver it with something that feels as bad as the stock seat, it is a little cruel.
    2019 Ryler Rally , Shock Yellow
  10. #35
    Jul 2019
    CO
    Quote Originally Posted by Tslepebull View Post
    They cut a lot of corners to get the price point as low as they did. There is a lot of OEM add on you can buy and aftermarket stuff to get it how you want. That is my issue right now. I just keep getting more stuff. I have already put thousands of more dollars into it and I am about to get the comfort seat. It's a drug Man, lol.
  11. #36
    Jun 2012
    Nevada
    That is the first I heard that the Rally seat was better or thicker than the Ace seat. They never advertised it as being better.
    -Jimmy
    2019 Ryker 900
    2018 Honda Goldwing
  12. #37
    Jun 2019
    Florida
    For those intending to put the stock seat back on, I have a suggestion/question. Why not just take a couple of those paper binder clips and pinch the foam pad in between them and slip the tabs through the seat pan holes? Then remove the binder clips from the tabs and it should hold, right? Is there enough clearance to do it without raising the whole contraption up?
  13. #38
    Active Member Winnex3's Avatar
    Feb 2016
    Paw paw mi
    It shows to do that in the shop manual
  14. #39
    Jun 2019
    Florida
    I do not have a shop manual so I couldn't have picked that up from there. I wonder if I had heard something like that from someone that had read it or tried it before? Getting old and can't remember. I haven't removed mine yet, but thought about it a few times. Guess I must have picked it up from someone on here or on Youtube or something.
  15. #40
    May 2009
    Connecticut
    I really don't think the Comfort seat was worth it to me? But it is "enough" better than the Rally that I'm not gonna take it off.
    If the Ryker had a Little bucket like seat like the stock F3 I would be in heaven because the Thing "Ryker" Just Engrosses you Sooo much in the ride that you feel part of the machine!
