that is probably the passenger sensor. it allows the passenger hand grip heater to work and the audio controls and I think that it adjusts the system braking also.
Dennis
Job 19:25 (NIV)
I know that my Redeemer lives, and that in the end he will stand upon the earth.
2015 RT-s
On my 2016 RTL that connection is for the sensor that sends the signal to the air pump to adjust the rear suspension depending on the passenger's weight. I think its the same for your 2018. It may also do other things like olsarge said but I'm not sure on that.
[SIGPIC]
2021 RT Limited Asphalt Gray
The wiring under the seat is a switch for the vehicle stability control to know when you have a passenger on board. It adjusts the limits where the stability control cuts back power. Has nothing to do with heated grips, audio controls or air suspension.
Removing the seat is actually pretty easy if you know how. Remove the passenger back rest (3 screws from inside trunk) then the bolts at the rear of the main seat are easy to access with a 10mm socket and ratchet. Do not drop the nuts.....
1998 Honda Valkyrie
2006 Mustang GT. Varooooom!
US Navy Veteran
Member: American Legion
Aha, thank you jc. I knew it had to be some feature I wasn't familiar with. Now I can get a good nights sleep tonite
GLIDE-ON>>>>>>>>>>>>>>
Heater grips and audio controls are mounted in the FRAME, not the seat.
That is a passenger sensor for the ABS/TCC.
If one were to order a heated seat, how hard would it be to install and wire it in? Would the wiring be easier to do with the BRP heated seat or equal with a custom aftermarket seat like Corbin?
I just installed a BRP Heated Comfort Seat on my RTS. It was a simple plug and play using the supplied OEM wiring harness.
1998 Honda Valkyrie
US Navy Veteran
