Results 1 to 11 of 11
    Active Member Valkrocket's Avatar
    May 2018
    Murrells Inlet, SC
    Default Seat question????????
    OK, I'm kinda baffled here. I don't read anywhere in the manual that the 18 RTL seat is heated. The grips yes, seat no. Yet when I removed my seat to install the backrest I had to unplug an electrical connection. I know the seat lock is electronic, but that latch is in the frame, the seat only has a post that fits down into that latch. There are no lights or any other kind of electronic device that wires into the seat.....that I know of. If the wire is there for a future mod to install heat, why not tell us that or better still, just add the switch to the fog light/heated grips cluster? As I said before, the Marquis de Saud designed the seat removal procedure but, musta had help from his brother(the Marquis de Keep'emguessing) So I call on you once again for your experience and/or wisdom
    GLIDE-ON>>>>>>>>>>>>>>
    2021 RTL Chrome , Petrol Blue
    Member olsarge's Avatar
    San Antonio, Texas
    that is probably the passenger sensor. it allows the passenger hand grip heater to work and the audio controls and I think that it adjusts the system braking also.
    Dennis
    Job 19:25 (NIV)
    I know that my Redeemer lives, and that in the end he will stand upon the earth.
    2015 RT-s
    Member Hooded Claw's Avatar
    Dec 2016
    Maine
    On my 2016 RTL that connection is for the sensor that sends the signal to the air pump to adjust the rear suspension depending on the passenger's weight. I think its the same for your 2018. It may also do other things like olsarge said but I'm not sure on that.
    [SIGPIC]
    2021 RT Limited Asphalt Gray
    2021 RT Limited , Asphalt Gray
    Houston
    The wiring under the seat is a switch for the vehicle stability control to know when you have a passenger on board. It adjusts the limits where the stability control cuts back power. Has nothing to do with heated grips, audio controls or air suspension.
    Removing the seat is actually pretty easy if you know how. Remove the passenger back rest (3 screws from inside trunk) then the bolts at the rear of the main seat are easy to access with a 10mm socket and ratchet. Do not drop the nuts.....
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Oct 2014
    Fort Mill, SC
    JC is right.
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    Member: American Legion
    May 2018
    Murrells Inlet, SC
    Aha, thank you jc. I knew it had to be some feature I wasn't familiar with. Now I can get a good nights sleep tonite
    They got you covered.
    Apr 2017
    North Central Florida
    Quote Originally Posted by olsarge View Post
    Heater grips and audio controls are mounted in the FRAME, not the seat.
    That is a passenger sensor for the ABS/TCC.
    Oct 2017
    Las Vegas, Nevada
    If one were to order a heated seat, how hard would it be to install and wire it in? Would the wiring be easier to do with the BRP heated seat or equal with a custom aftermarket seat like Corbin?
    2017 RTS , Blue
    Oct 2014
    Fort Mill, SC
    Quote Originally Posted by johnsimion View Post
    I just installed a BRP Heated Comfort Seat on my RTS. It was a simple plug and play using the supplied OEM wiring harness.
    1998 Honda Valkyrie
    US Navy Veteran
    Sep 2018
    greensburg,pa
    2018 RT-L , Blue
