Results 1 to 6 of 6
Thread: Trailering
    Very Active Member Zip's Avatar
    Sep 2016
    LI NY
    Cool Trailering
    Good morning,
    I have been trailering my spyder for about 4 years now it is an SM5. When I strap it down I put it in Neutral with the parking break on. When I get to my destination I notice that the rear wheel has rotated about 1/8 turn.
    My friend just bought the same trailer as mine. He was told to strap it down in 1st gear with the parking break on, he has an SE6.
    My concern is that leaving it in gear will put unnecessary pressure on the clutch and transmission with it in gear.
    Anyone have thoughts on this?
    Thanks Jeff
    2010 RTSM5
    Nov 2012
    North Las Vegas, NV
    On an SE it won't matter because the clutch allows it to roll. I trailered my 2 wheeler across the country twice had it in first gear and it was fine. If you set the park brake on the spyder it shouldn't move.
    2012 RT Limited (Traded)
    2016 F3 Limited
    2010 Vulcan Voyager
    2014 Suzuki V Strom 650
    Aug 2012
    CO
    We trailered our SM5 in the back of the toyhauler with parking brake on and in gear. With proper tie downs your bike should be fine. The rotation of the wheel is from the back end bouncing off the floor.
    Current stable: 08 Spyder RS "Big Bird" \ 12 Street TripleR "Stripper" \ 02 VFR800 "Big Red" \ 09 KLX250S
    Sold List: 97 Ninja500R, 03 SV650K3, 01 Ducati 750Sport Dark, 73 CB350/4, 03 F650GSA, 08 Gixxer600, 03 Gixxer600, 91 VFR750F, 09 KLX250, 06 Thruxton 900
    JLohPhotos
    Nov 2018
    N.E. Ohio
    Strap your back wheel down and problem solved. cueman
    Oct 2017
    Las Vegas, Nevada
    When you're trailering, you're really just parking it permanently in one place on the trailer. I was taught on a manual transmission car to put the car in gear when parking it. I see no reason why a manual transmission Spyder would be any more delicate than a car. What does your manual say about how to park it? Does it say to leave it in gear or not?
    Jan 2015
    southern WI
    Put a strap over the rear wheel in the travel direction...no more issues!
