Results 1 to 4 of 4
Hybrid View
    Active Member Spydermike's Avatar
    Mar 2018
    Maricopa, AZ
    Default Replacing dash gauge - what do I need?
    Ok so here's my goal: I want to replace the gas gauge on my RT with a voltmeter/usb charger, it's almost identical to this - https://www.amazon.com/LiDiVi-Waterp.../dp/B01M0GR0FQ
    I realized it's not the same size as the gauge (52mm), so what would be the best and easiest way to make it a good fit?
    1. Buy a blank gauge cover, measure and cut out an opening and fit it in the cover then install into the dash?
    2. I know JT's has a dash gauge power product - http://spyderstore.com/index.php?rou...&product_id=62, but will the charger/voltmeter I bought fit in that piece, or do I need further modification?
    3. Is there another option I don't know about?
    I looked through the forum and searched but haven't really found the answer I was looking for. Hoping some of you fine folks can help me out
    Mike
    2016 RTL "Boris"
    Foam Grips
    Utopia Backrest
    BRP Passenger armrests
    Bajaron sway bar
    LED Bumpskid w/remote
    Belt guard
    BRT rear lighting w/strobe
    High mount BRT w/strobe
    Dual a-arm LEDs w/turn signals
    Multicolor underground Halo lighting
    LED headlights and foglights
    FOBO TPMS
    Techgripper phone holder
    Lidlox
    Dual USB with voltmeter
    Dakota Digital Compass/Clock/Altimeter/Temperature Gauge
    Vredestein Quatrac 5 175/55R15 - Fronts
    General Altimax RT43 215/60R15 - Rear
    Dec 2015
    NE Ohio
    I bought 2 52mm blanks from an online store, forgot the name. They are more than just face plates.Check out marine suppliers.
    In my case, I drilled out a 1" hole to mount the USB unit and I also replaced the other gauge with a 12v outlet. I used the factory plugs for power and just inserted the bare wire into the correct holes. Worked for me, not elegant but functional.
    Mar 2018
    Maricopa, AZ
    Quote Originally Posted by KosherKid View Post
    I already bought a blank, so I can just cut a 1" hole and it should fit. Do you think you can post a pic of yours so I can see what the end result looks like?
    Thanks!
    2016 RTL "Boris"
    Foam Grips
    Utopia Backrest
    Bajaron sway bar
    Belt guard
    FOBO TPMS
    Lidlox
    Dec 2015
    NE Ohio
    I can try. The Spyder is in a storage locker during the snowy season. I'll snap a pic tonight.
