Results 1 to 6 of 6
    Very Active Member Tslepebull's Avatar
    Dec 2018
    East Texas
    Default Vibrating plastic panels
    I am trying to track down the source of vibration and buzzing of the plastic body panels on my Rally model. Ideally I would like to hear more of the motor and less of the cacophony of plastic parts. Anyone have success in identifying the offending parts and either fixing them in place or padding them to they cant buzz? I did find an inner panel on the left side that had some play and used a piece of wadded up aluminum foil to stop the movement but other places linger.
    Please don't get me wrong; I am not BRP bashing. I just want to make my riding experience as good as it can be. and yes, I do wear hearing protection when I ride.
    2019 Ryler Rally , Shock Yellow
    Thinks out loud Jeriatric's Avatar
    Apr 2012
    You could install low density foam(like weather strip foam) anywhere you suspicion there to be a contact problem. as always >just, thinking out loud
    Dec 2018
    East Texas
    That is my long range plan. I am just trying to locate likely spots to start before I take all the body panels off. No point in over-complicating it if someone else has already found some likely locations.
    Kansas
    I found a few panels not installed properly when removing some to do the sway bar upgrade. Idiots at the dealership I'm sure.
    Jun 2012
    Nevada
    I found this on mine a while back.
    https://www.spyderlovers.com/forums/...king-noise-FIX!
    -Jimmy
    2019 Ryker 900
    2018 Honda Goldwing
    Florida Swamp
    2019 F3-S , Black & Silver
