Results 1 to 12 of 12
    Jan 2019
    NW Indiana
    Default Ryker Windshield Bulletin
    If you have not already installed a windshield and broken the tabs, an update is available with the dealer saying to use 2 washers on the mount tabs so as not to break them off by bending them inward as you tighten the screws.
    I broke tabs on both of the windshiels before I realized why....I will call the service manager in the morning to see about replacments.
    Happy riding
    Mac
    Jan 2019
    Charles Town, WV
    I found that problem out as well. I looked at mine and thought I should add some washers but then said maybe it will pull in. Well I broke off the tab on one side. If you take a small paint brush with some acetone and rub on the edges of both pieces until is softens a bit (you will see a little black getting on the brush). Push the two pieces back together and hold for a minute or so and that will glue them back together. I did this then installed with washers, I use 2 on one side and 1 on the other and it worked fine.
    Jan 2019
    North Carolina
    I bought a windshield but I haven't got it yet. Do you mean, two washers stacked up against each other?
    So, two each in these spots or one on top and one below?
    2019 900 Rally Edition , Black w/Yellow Panels
    Jan 2019
    Charles Town, WV
    Yes on the top two screws. I used 2 washers on one top screw and 1 washer on the other top screw. 1 washer on each screw may work but since I broke mine and glued it back together I did not want to put any stress on it.
    Very Active Member Tslepebull's Avatar
    Dec 2018
    East Texas
    My dealer installed the windshield on my Rally. I will look for cracks.
    2019 Ryler Rally , Shock Yellow
    Aug 2007
    Greeneville, TN
    Awesome information! I've got a windshield coming. Should be here today or tomorrow. I love this forum as it keeps us from all learning the hard way. Information gets discriminated quickly instead of slowly seeping through the grape vine. I'd surely have broken my windshield had this thread not been posted. So I thank you very much! And so will many others!
    Active Member QuasiMotard's Avatar
    Jan 2019
    Houston, TX
    +1
    My windshield is still in the box, so I'm glad I read this before finding out the hard way.
    QM
    Jan 2019
    NW Indiana
    Update: Spoke with my dealer yesterday. As soon as I told him who I was (I bought two Rykers) he laughed and said, "I was just talking to the salesman to get your number. I ordered replacement parts and the washers for you, I'll call as soon as they come in." No charge and a fun learning experience. It never occurred to me to look for clearance in the mounts. Lesson learned.
    Aug 2007
    Greeneville, TN
    Installed my windshield yesterday. The metal cast brackets do not match up to the tapered mounting point as well as they could. And there is quite a gap between the upper (Plastic) mount points and the metal bracket. Everything works fine so the end result is the same. But somewhere the engineers got their specs a bit off. 2 thick washers (One on each side at the top) did the job for me.
    Dec 2018
    East Texas
    I's cold in Canada eh! Stuff shrinks, ja know..
    Default Good to know
    Looks like you have already saves some folks from making the same mistake. Hope everyone with that windshield get a look at this post....
    ​2012 RS sm5
    SpyderLovers Sponsor F4 Customs's Avatar
    Nov 2012
    Twinsburg, Ohio
    F4 Customs is working on a new windshield for the Ryker. Should have some good info soon.
    F4 Customs, Inc.
    "The Motorcycle Windshield Folks"
    941-347-7496
    sales@f4customs.com
    <a href='http://www.spyderlovers.com/adserver/www/delivery/ck.php?zoneid=22' target='_blank'><img src='http://www.spyderlovers.com/adserver/www/delivery/avw.php?zoneid=22&cb=567846784' border='0' alt='' /></a>
Tags for this Thread
