Results 1 to 5 of 5
    Active Member CharlieIndia's Avatar
    May 2011
    Washington Pa.
    Default Horn location 2018 RTL
    Couldn't find where the horn is located on a 2018 RTL, did a search of this site and others to no avail. Anyone have any knowledge of where it's located?
    Jul 2014
    Mint Hill, NC
    I believe they moved it from the left side on '14-15 MYs to the right side. You have to remove the right Side Panel per pg 39 of your operator's guide to get to it. Be certain to clip the top rear of the panel when reinstalling it or you might lose it at speed.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    May 2011
    Washington Pa.
    Thanks JayBros
    Jan 2015
    southern WI
    My 2016 RT was still on the left side just behind the lower panel....can't speak for the newer models
    2021 RT Limited
    2016 RTS , Pearl White
    Active Member MeudtPG's Avatar
    Aug 2018
    Monroe, WI
    I have a 2018 RTL. When I was installing the new Spyderpops Next Generation LED Bumpskid and A-arm LEDs I discovered the horn. It is under the bottom panel on the right under the frunk. You need to lift Spyder up on ramps or jack stands to crawl under to get at removing panel (I think one screw and three push pins).
    Just remove the panel and you will easily find it. Hope this helps.
    "BLUE STAR – She shines so brightly"
    2018 SPYDER RT LTD SE6 BLUE/CHROME
    2018 RTL , Large Brake Pedal (cut 1/3 off). Oxford Blue/Chrome
