Results 1 to 7 of 7
    Active Member Raprider's Avatar
    Oct 2017
    Central NJ
    Default How to Clean a Dirty Dash Panel
    Somehow have some liquid staining behind the plastic on my dash...right side on the tach from 3-6 and left side on the speedo next to 60-100.
    I removed the torx screws on the panel surround, but this doesn't allow me to just remove the plastic panel to clean the back of it.
    What else do I need to remove???
    Thanks!
    Rap
    p.s. Yes, i finally clicked 3k miles on Blackbird yesterday... Thanks, groundhog
    Raprider (Rich)
    2016 Can-Am Spyder ST-S SE5 Steel Black Metallic (Blackbird)
    BRP Audio, Heated Grips, Fog Lights, Passenger Backrest, Givi Saddlebags/Top Case
    BajaRon Swaybar, TricLed Wide-Vu Mirrors, Lamonster Ram mount and X-grip, Sena 20S Evo Dual
    TricLed Sequential Front SpyderFenderz, Dual Color Run/Brake/Turn LEDs, Brake Flasher
    Kumho Ecsta AST installed on rear 4/2021
    1996 Yamaha Virago 750 (Vera) - still riding
    1987 Honda Shadow 500 (Shady) - sold
    1982 Honda Rebel 250 (Little Reb) - sold
    Active Member Ex Winger's Avatar
    Apr 2015
    Brockville ONT
    Not sure about the ST but on my 2015 RT it was a common problem with the staining on the plastic glass over the tach and speedo.BRP replaced it under warrenty.
    2018 RT Anniversary , Brake pedal extended
    Vermont
    This picturedashboard on spyder14RT 003.jpg might help you:
    I have a 2014RTS-SE6.
    The above picture was part of the process to paint the dashboard( seen in any of my threads, or posts).
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Member Green1's Avatar
    Sep 2018
    Lebanon PA
    Here's a video on how to do it.
    https://www.youtube.com/watch?v=I4Hvpc7wJYk&t=44s
    Bossier LoUiSiAna
    U can try removing the whole cluster (described in manual for changing headlights) the clear lense is not supposed to remove however, if you have a leak maybe you can find it & suck the water out somehow, or warranty claim
    Oct 2017
    Central NJ
    Nice! If only uncle Bob (as mentioned in the video) would perform the multi-panel removal required to clean up something that isn't supposed to happen in the first place...
    Raprider (Rich)
    Oct 2017
    Central NJ
    Just following up on this...since it was nice enuf today to spend some quality time in the garage.
    Watched the vid and went out and tackled this...and very pleased with the results.
    And then took 'er out for 40 Yay spring!!!
    Raprider (Rich)
