Somehow have some liquid staining behind the plastic on my dash...right side on the tach from 3-6 and left side on the speedo next to 60-100.
I removed the torx screws on the panel surround, but this doesn't allow me to just remove the plastic panel to clean the back of it.
What else do I need to remove???
Thanks!
Rap
p.s. Yes, i finally clicked 3k miles on Blackbird yesterday... Thanks, groundhog
Raprider (Rich)
2016 Can-Am Spyder ST-S SE5 Steel Black Metallic (Blackbird)
BRP Audio, Heated Grips, Fog Lights, Passenger Backrest, Givi Saddlebags/Top Case
BajaRon Swaybar, TricLed Wide-Vu Mirrors, Lamonster Ram mount and X-grip, Sena 20S Evo Dual
TricLed Sequential Front SpyderFenderz, Dual Color Run/Brake/Turn LEDs, Brake Flasher
Kumho Ecsta AST installed on rear 4/2021
1996 Yamaha Virago 750 (Vera) - still riding
1987 Honda Shadow 500 (Shady) - sold
1982 Honda Rebel 250 (Little Reb) - sold
Not sure about the ST but on my 2015 RT it was a common problem with the staining on the plastic glass over the tach and speedo.BRP replaced it under warrenty.
The above picture was part of the process to paint the dashboard( seen in any of my threads, or posts).
Deanna
Gremlin Bell
SpyderPops Missing Guard Belt
Ultimate F3 Floorboards
Sway Bar with Links
Rolo Laser Alignment
Half Cover
Show chrome Trunk Shock
U can try removing the whole cluster (described in manual for changing headlights) the clear lense is not supposed to remove however, if you have a leak maybe you can find it & suck the water out somehow, or warranty claim
Nice! If only uncle Bob (as mentioned in the video) would perform the multi-panel removal required to clean up something that isn't supposed to happen in the first place...
Raprider (Rich)
Just following up on this...since it was nice enuf today to spend some quality time in the garage.
Watched the vid and went out and tackled this...and very pleased with the results.
And then took 'er out for 40 Yay spring!!!
Raprider (Rich)
